1997 ram 1500 cluster/ exterior lights
Old Mar 16, 2020 | 09:34 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Justinbryant92
The switch it self looked fine so I might try the plug first and see if that helps at all. Is there a write up on some sort of hd setup or is that kinda risky and possibly burn up more things?
LMC sells a HD relay harness. You could make one if you wanted
Old Mar 21, 2020 | 01:21 PM
Justinbryant92's Avatar
Justinbryant92
Default Update
Finally found out the whole issue it ended up being a ground wire that ran from the battery and grounded to the radiator support. It wasn’t connected so I connected it back to the battery and everything came back alive like normal.
Old Mar 21, 2020 | 09:58 PM
Wow. Didn't realize that wire was quite that important. Good info. Thank You.
Old Mar 21, 2020 | 10:08 PM
MoparFanatic21
Was it a main ground wire?
Old Mar 22, 2020 | 10:30 AM
Moparite's Avatar
Moparite
A lack of a ground wire won't burn up the connector like that so it seems you have/had two issues. This is a common issue with the second gens and there was a recall for the 3500's. As you see it wasn't limited to just the 3500. If you don't want to add/change the harness you can swap out the running lights with led's(no resistor ones). This will cut the amount of amps running threw the light circuit and "should" eliminate the problem. You will have to change the flasher to a HD one so the blinkers work correctly.
http://dodgeram.info/tsb/recalls/819.htm
Old Mar 23, 2020 | 10:57 PM
AtomicDog's Avatar
AtomicDog
Thank you for that. Helps out a ton.
I literary just found my headlight switch has a burnt wire on the connector plug. So I might start with that. Sucks that plug is 50 bucks lol but maybe that’s one of the problems but hopefully that’s the issue lol
FYI, the switch and harness combo is available for about $38 via Am-Autoparts delivered to your door within the USA.
