96 ram 1500
Old Mar 25, 2020 | 06:06 PM
olered1's Avatar
olered1
Default 96 ram 1500
My emergency brake & cable was removed because of a technical issue. Since then, my cruise control won’t work. Help.
Old Mar 25, 2020 | 08:21 PM
The two are not connected in any way. More likely, the vacuum line going to the cruise servo, under the battery.... broke.
Welcome to DF! Moving this to Second Gen Ram section.
Old Mar 25, 2020 | 10:19 PM
olered1's Avatar
olered1
brake light is on also
Old Mar 25, 2020 | 10:20 PM
olered1's Avatar
olered1
Brake light is on also
Old Mar 26, 2020 | 11:13 AM
Might be a bad brake switch then. Have you tried pulling the e-brake pedal up? See if the lite goes off?
Old Mar 26, 2020 | 02:08 PM
olered1's Avatar
olered1
E-brake pedal is gone
Old Mar 26, 2020 | 05:56 PM
Is the switch for it still drifting about? How about the connector for said switch?
Old Mar 28, 2020 | 05:19 PM
olered1's Avatar
olered1
Where would it be??
Old Mar 28, 2020 | 06:05 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by olered1
Where would it be??
would be up where the emergency brake pedal would be
