Yet another issue on a 98 4x4 popping while engaged
Old Apr 2, 2020 | 08:06 PM
Jessehendrixp1's Avatar
Jessehendrixp1
Default Yet another issue on a 98 4x4 popping while engaged
Ok guys so as ive been driving my truck around I thought id try the 4x4 out to make sure it worked properly...... Well *price is right failure ding* there is an issue..... At first the shifter would only go into 4lo which I later figured out was change in the way of the shifter got that out of there anf it worked smooth....... It seems to shift in anf out of 4 wheel fine and smooth both hi and low but as I give it gas there is a kinda popping/clunking every few seconds seems to only happen when going straight and doesnt do it if the engine is crawling with its own power(no pressure on the gas pedal) or of the wheels are turned either direction..... Anyone ever had this happen? Anything similar? A friend told me my the chain in my tcase is strectched but I'm not so sure with it engaging like it does and working good other than the intermittent clunking also seems to have a quick succession of a few pops when slowing down/ coming to a stop
Id also like to add that ive done this on different terrain wet pavement, wet grass, and gravel same thing on all
Old Apr 2, 2020 | 08:26 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Could be a universal. You sure it isn't a clicking?
Old Apr 2, 2020 | 08:39 PM
Yeah, that front u-joint is notorious for going out. Makes some really rude noises too. Crawl under there, and have a look at everything, see if anything obvious presents itself.
Old Apr 2, 2020 | 08:43 PM
Jessehendrixp1
I will do the truck is actually being painted but I'm supposed to get it back tomorrow I'll post up on what I find...... Will I be looking for just general play in the u joint? If it is bad Will I be able to grab hold of the driveshaft and get it to move?
as for the clicking it is kind of a clicking but somtimes it will literally thud and vibrate loud througout the cab on bad one's
Old Apr 2, 2020 | 08:45 PM
Yeah, the front one is easy, the two in the CV joint though, they always have some tension on them, and its really hard to tell if they are bad or not. Gotta pull the shaft, and play with 'em. After replacing my front joint twice on my 96, I just spend the money and had the whole shaft rebuilt. Then sold the truck later the same year..... Ooops.
Old Apr 2, 2020 | 11:01 PM
MoparFanatic21
There is also a "centering ball" called a CV ball on the cardan joint that can go bad
Old Apr 3, 2020 | 04:33 AM
Jessehendrixp1
There is a driveshaft shop here in town I'm beginning to wonder if it woyldnt be a bad idea to just take the front shaft to them and have them replace everything........... Can the ball be replaced easily I know ujoints are supposed to be a real pain
Old Apr 3, 2020 | 07:44 AM
Yeah, everything is available. That's what I had them do with mine. (for about 300 bucks..... had I known that, I would have just bought a new one.....)
Old Apr 3, 2020 | 11:41 AM
MoparFanatic21
Everything is real easy to replace
Old Apr 4, 2020 | 04:26 PM
Jessehendrixp1
Yea got my truck back and took a look definately pretty much every I joint has play in it...... I think I'm gonna try to do them myself I'm pretty handy mechanically I just havent changed one but watching videos they dont look to bad.....
are there any how tos or step by steps you guys know of?
