Drilled out a Plenum Pan Stripped Bolt Hole on 97 5.9 GAS
Like an idiot, I drilled all the way through a plenum pan hole on intake after it stripped, thinking I cld put a wing nut on the inside to hold the bolt on. Bad idea, then I fixed threads, got a tight bolt in there and put some black gasket maker on bottom of hole, under bolt. Had no start problems ever since.
Could this be the reason and do Ineed to replace the intake manifold no matter what or wld the bolt being tight give it an airtight seal? Thanx for any help guyz.
Edit
Edit
The following users liked this post:
Vince Adelman IV (06-27-2020)
If it ran good before you pulled the intake, but won't start now.... Then it is highly likely it is something you did in the process preventing it from starting. Did you do anything with the crank sensor during the work? Cam sensor? Is the temp sensor by the thermostat housing plugged in?
See what you are missing. Does the fuel pump prime when you first turn the key on? Are you getting spark? Adequate fuel pressure? Is the PCM firing the injectors?
Vince Adelman IV (06-28-2020)
Temp snsr was plugged in, possible it cm loose but pretty sure I alwayz checked it to make sure.
Anytime it wld not start, I cld not see a spark w light test, when I sat in driver seat and tried turning it over.
Gotta listen to fuel pump prime. Gotta test for spark again and see how I can test for fuel press, thr is no schrader valve along port rail. Gotta also see how i can test pcm firing injs.
It has been a nightmare since it last broke down.
Drove abt 40 mis, made a few stops then wldnt start after sitting at a rstrnt for an hr. Wld not start but started after i held gas pdl dwn, as I turned key. It coughed a little as it started, which is sthing it never did before. Drove it home and that was last time it started and ran. Engine has alwayz been strong.
I did add a valley pan in process of repl manifold gaskets but I dnt think it shld matter. When cranking, it sds like compression is strong, I think. Took it to a tire ctr and they worked on it for 11 hrs and cld not fig it out. Then had it towed to career ctr/HS who does free wk and they cld not fig it out when virus shut dwn the school.
Now, I am thinking of having it towed bk home and testing this stuff that I shlda tested before.
Yeah, drag it home so its more convenient to work on. You can rent "Noid lights" to test for injector pulse. Fuel pressure is gonna be a problem on the 97, plastic fuel rail... no test port. So, need a selection of adapters. (parts store *might* have it for rent....)
Something is getting hot, and failing.
Trending Topics
