Overheating issue
Old Jul 14, 2020 | 12:01 AM
  #21
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 96albertaram
Alright! So tapped new hole and swapped sensors and boom! I have my gauge back! Its only been 5 years without! I changed out both rad hoses and thermostat while I was in there. BUT I have a leak in that area now. What do you recommend to seal the thread on sensors ? I Hope's that's where it's coming from
It's most likely from the thermostat housing as it's common to leak there. I used thread sealer on the sensors and rtv plus a CORK gasket (it's thicker) on the thermostat housing
Old Jul 14, 2020 | 12:18 AM
  #22
96albertaram's Avatar
96albertaram
Rtv on the cork gasket? Is it common to leak where the sensors are?
Old Jul 14, 2020 | 12:19 AM
  #23
96albertaram
I'll have to track down a cork one. This one was like a stick on style
Old Jul 14, 2020 | 08:00 AM
  #24
Verify where the leak is coming from first. You *should* need to use anything on the threads...... Most that I have seen, if they are not dependent on contact with the manifold for their ground, they already have some thread sealer on them, right out of the box. If it IS leaking around the sensor, just tighten it up a bit more.
And yeah, the thermostat housing is notorious for being difficult to seal......
Old Jul 14, 2020 | 08:33 AM
  #25
96albertaram
Ok ya after work I'll try to tighten them a bit more. Maybe I should find correct torque specs for thermostat housing
the last gasket that was on here looks like same material as one I have on now and didnt have any leaks beforehand .
Old Jul 14, 2020 | 08:41 AM
  #26
That was supposed to be *shouldn't*....... Darn keyboard.
I usually put a think coat of RTV on both sides of the thermostat gasket......
Old Jul 14, 2020 | 08:49 AM
  #27
96albertaram
Ok ya. Looks like I'm tearing it off again. It's hard to tell where its leaking when there all so close together lol
Old Jul 14, 2020 | 08:50 AM
  #28
Pull the a/c compressor out of the way, makes seeing in there much easier. Also lets you look at the bypass hose. (notorious for 'mystery' coolant leaks. )
Old Jul 14, 2020 | 09:30 AM
  #29
MoparFanatic21
I forgot about grounding to the case, so thread sealer would be a bad idea! As HeyYou said verify where the leak is first
Old Jul 14, 2020 | 09:50 AM
  #30
true blue's Avatar
true blue
Years back, an old dinosaur mechanic told me to stop using "any kind of sealer" on the thermostat gasket. Use the plain paper style gasket with no sealer. The paper gasket swells from the antifrz encroachment and it swells up n, voila! I've been doing it on these stupid mopar thermostat housings for 3 decades now. No leaks. Just don't over torque your bolts and crush the gasket.
