Downstream O2 sensor rough idle?
Old Jul 17, 2020 | 01:32 AM
Steve114343's Avatar
Steve114343
Default Downstream O2 sensor rough idle?
Hello everyone,
I need some advice. I have a 1998 ram 5.9 has 111k miles. I have put new spark plugs, wires, Cap, rotor, coil, map sensor, iac, TPS, Valve cover gaskets, all new fluids, and just got done with plenum repair all new vacum lines and upstream o2 sensor. I have a bit of a rough idle and it had it when I bought it a couple months ago. Can’t figure out what it is. Did compression test and leak cylinder test and all checks out great. Could the downstream o2 sensor be the problem? I also have no cat. Can’t figure this one out. Any help would be greatly appreciated. Thanks
Old Jul 17, 2020 | 09:18 AM
Downstream won't be the issue, it really doesn't have much of an effect on fueling. It's just to monitor the cat. What brand front O2 sensor did you put in? If it's a bosch, that's likely part of the problem. NTK or Denso O2 sensors only please.
Old Jul 17, 2020 | 11:08 AM
Steve114343
Yeah I put NTK.
Old Jul 17, 2020 | 02:26 PM
Ok, so, that shouldn't be it.
Do you get any codes for misfires? Can you check misfire counters? See which cylinder(s) is(are) the issue?
Old Jul 17, 2020 | 02:36 PM
Steve114343
no codes. Misfire counters?
Old Jul 17, 2020 | 02:38 PM
Yeah, need a fairly billy scanner that can read data. Misfire counters should be listed for each cylinder. (assuming the PCM can count, the one in my truck sure can't...... I had a DEAD miss, that NEVER set a code.)
Old Jul 17, 2020 | 05:53 PM
Steve114343
hmm ok. Im gonna look more into that and see if I can get a good reader. What about the purge solenoid would that have anything to do with it? Thanks
Old Jul 17, 2020 | 05:55 PM
Maybe if it is stuck open, which would essentially be a vacuum leak.
Old Jul 17, 2020 | 06:23 PM
Steve114343
thanks for all the information. I’ll let you know what I find. Gonna check the purge solenoid tommorrow and see if I can get a good scan tool to count the misfires.
