No power to fuel pump
Old Aug 15, 2020 | 05:10 PM
Don Pollard's Avatar
Don Pollard
Default No power to fuel pump
Hello all. Ive searched several forums trying to figure out a fuel pump issue and seem to see some funky solutions. I installed new pump a couple months ago. Has worked fine. Come to find out I really didn't need a new pump. It was the F8 fuse. 4 days ago and I'm not getting power to fuel pump. Changed and checked all fuses and have tried jumping relay and get nothing. Checked pcm fuse it's good and did a pcm reset even. At a loss and looking for input. Thank you
Old Aug 15, 2020 | 09:08 PM
What are you driving?
Old Aug 15, 2020 | 09:13 PM
Don Pollard
As I posted it's a 97 Dodge ram 1500 5.2l engine
Sorry I thought I posted that. New to this. Lol
Old Aug 16, 2020 | 08:46 AM
Moving this to second gen ram section for ya.
Does the pump prime when you first turn the key on?
Old Aug 16, 2020 | 12:06 PM
Don Pollard
No it does not when key is turned to the on position
Old Aug 16, 2020 | 12:09 PM
Grab the service manual for your truck from here.
Try putting a jumper across the fuel pump relay, see if the pump runs/engine will start.
Old Aug 16, 2020 | 12:12 PM
Don Pollard
I tried jumping pin #30 and #87. Nothing. I also have power on both sides of fuse #8
Old Aug 16, 2020 | 12:16 PM
Don Pollard
One thing that has me curious is when fuel relay clicks my ac clutch clicks too. If pull fuse #8 with key in the on position and plug fuse back in I can hear pump prime. But when you try to start fuel doesn't pump.
Old Aug 16, 2020 | 02:22 PM
Is that fuse 8 in the junction block in the side of the dash, or in the PDC under the hood?
If pulling/replacing the fuse causes the pump to run, it should also run when you first turn the key on.... That's kinda weird.
So, you obviously are getting power at pin 30..... Does the relay click when you first turn the key on? (should click once, then three seconds later, click again.)
Old Aug 16, 2020 | 02:37 PM
Don Pollard
Yes it's #8 in the PDC. Pin 30 is constant 12v and when I checked the pins with key in on position I have power to pin 30 87 and 86. I know this because I didn't push relay all the way down and touched the relay pins with tester. I know relay clicks when I turn key on and pull #8 fuse and push it back in. I'm by myself so it's hard to test power at fuel pump.
