Help with misfire and bogging down
Old Sep 29, 2020 | 04:24 PM
  #141
Goshdarnram's Avatar
Goshdarnram
Oh okay yeah I think that one might work I’ll start there and see
Old Oct 17, 2020 | 07:15 PM
  #142
Goshdarnram
so this sweet started happening I haven’t fixed anything yet just drove the truck yesterday in 2weeks or so And noticed this it sqeeks every time I turn the wheel at a certain point like 1/8 left then 1/8th right only at that certain spot I noticed it was poping a lot Over small bumps and slow turns and sometimes it would jerk left
Old Oct 17, 2020 | 09:08 PM
  #143
Grease everything. See if it's any better. Sounds like a dry joint somewhere, possibly binding as well.
Old Oct 17, 2020 | 09:14 PM
  #144
Goshdarnram
Think that could cause the steering issues I’ve been having? I’m not sure what that parts called but I can feel the almost poping under The floor bord when I’m driving
Old Oct 17, 2020 | 09:24 PM
  #145
If yours was the one having no power steering turning one direction, then no, it won't cause that.... but, if it's binding, it will give you some odd steering issues.
Old Oct 17, 2020 | 09:30 PM
  #146
Goshdarnram
Oh okay I’m taking the truck to a suspension place Monday I’ll keep everyone updated and let y’all know what it is
Old Oct 22, 2020 | 07:32 PM
  #147
Goshdarnram
Hey so today I changed the drag link because it was poping binding right there fixed it still didnt fixed steering I didn’t really expect it to but I changed the oil while I was there because I noticed when I was driving 1hour 2x within the hour the oil pressure dropped to 0 for a split second no weired noises or anything so I drove home and checked oil seemed over full but dipstick was black so hard to really see so I changed the oil and only 3qt came out of the oil pan I know they take 7qt it was cold when I changed it I put 7qt in and the oil pressure is now reading at 3/4 from the max any info ideas is it okay to drive it it’s not smoking making no noises or anything
Old Oct 22, 2020 | 07:38 PM
  #148
The pressure sensors wear notoriously failure prone...... May be as simple as that. Being that low on oil, I'm not real surprised it would zero out though..... especially cornering, or coming to a stop.
Old Oct 22, 2020 | 07:41 PM
  #149
Goshdarnram
It did do it once out of the 2 times when I stopped at the house I’m just worried I over filled it bc of the dip stick reading full when I was on 3qt I let it drain for over 30mins and replaced filter and everything
  #150
Goshdarnram
It read it when I was on 3qt full and now after i put the 7 it’s still reading full over full I ment
