Help with misfire and bogging down
Old Dec 3, 2020 | 06:24 PM
  #231
Goshdarnram's Avatar
Goshdarnram
How much in y’all a area is it to get some seats re upholstered my seats are 1200$ Just for the front 2
Old Dec 3, 2020 | 09:38 PM
  #232
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Never went to a to shop I plan on doing a Katzkin kit. It's not hard. You could even buy the foam ($50 a piece) plus the covers (found them on eBay for $250 a set). Some hog rings and hog ring pliers and you are good to go.
Old Dec 3, 2020 | 10:06 PM
  #233
Goshdarnram
Never really looked into doing it myself but for 1200$ I’d much rather them be less then perfect then pay that much the foams not bad on them just the leather is completely messed up on the driver side on passenger it’s just where your back is at also while I have y’all ever hear anything good about the red battaries with the circle tubes on it? My battery is shot truck keeps dieing if I don’t drive it every few days and a recommended battery charger would be much appreciated
Old Dec 4, 2020 | 12:16 AM
  #234
MoparFanatic21
I would replace the foam anyhow because it stays compressed and they is what causing the seat cover to rip. Lol up videos on it (people have done 2nd gens) is not hard at all. They may be charging you too create a new cover. You can even put in heated and cooled seats if you'd like
Those batteries are usually really good. They are made for running a lot of accessories. I believe they are AGM batteries. I would say it's overkill if you aren't running a lot of accessories.
Old Dec 4, 2020 | 01:30 AM
  #235
Goshdarnram
Oh okay I will thank you very much
Old Dec 6, 2020 | 11:21 PM
  #236
Goshdarnram
Hey had another problem wandering what y’all thought it was my truck runs drives cranks fine but if I don’t drive it every 3 days it will need to be jumped off then I drive it for a day or 2 park it and then 3 days later if not driving it it needs to be jumped off again?
Old Dec 7, 2020 | 12:28 AM
  #237
MoparFanatic21
You got something drawing power. Common things are glovr box light or ash tray light. Could be just a weak battery also
Old Dec 7, 2020 | 12:33 AM
  #238
Goshdarnram
Ash tray light and cigarette light doesn’t work I will check dash light would a battery cut off fix this problem or would it be more trouble/expensive then just getting it fixed my a mechanic
Old Dec 7, 2020 | 02:20 AM
  #239
MoparFanatic21
Personally that's up to you and whether you would install it and where but yes it would. Me I would track down the problem first. You have something that is staying on causing the battery to drain overnight. Now if your battery is old, they also could be it. If you want to text something pull the I.O.D fuse from the fuse panel on the inside of the truck see if it still does it (this is where must problems come from). Just know you'll have to put it in before you start the truck
Old Dec 7, 2020 | 02:22 AM
  #240
Goshdarnram
What’s the IOD fuse?
