Help with misfire and bogging down
Old Jan 7, 2021 | 01:30 PM
  #331
Originally Posted by Goshdarnram
Figured new rear brakes couldn’t hurt lol
I am generally a big fan of "new".
Old Jan 7, 2021 | 01:33 PM
  #332
Goshdarnram's Avatar
Goshdarnram
Me to lol do you recommend new drums as well? Do they resurface those?
Old Jan 7, 2021 | 09:15 PM
  #333
Goshdarnram
I got the new shoes on it and caliper thing but I noticed when doing the old jack back end up putting it in reverse then slamming brakes to know the drum loose that my speedo would start climbing up to 30 when I’m not hitting gas how I realized this was I went to put it in park and it tried grinding and looked and was climbing what I did to put it in park was put it in nutral and it stopped and then park but what was wired was rpms wasn’t rising that much
Old Jan 7, 2021 | 10:07 PM
  #334
Consider that if you have the truck in gear, on a relatively level surface, it will move in the direction the gear shift indicates, even without stepping on the gas. It may even upshift...
Old Jan 7, 2021 | 10:10 PM
  #335
Goshdarnram
Oh wow I had no idea about that thank you also the new brake drums made a huge e brake difference the now I know my e brake works lights still on but it works now
Old Jan 8, 2021 | 10:28 PM
  #336
Goshdarnram
Hey rooky question but today I was trying to bleed my brakes (started back passenger first then back driver then passenger then driver) but I could not get the brake pedal to firm up at all I could drive it but my foot would almost go to the floor any ideas? Am I doing something wrong
Old Jan 8, 2021 | 10:38 PM
  #337
Goshdarnram
I think after research it’s my rear drums are not adjusted properly
what’s the correct protocol for adjusting rear brakes? I thought they self adjust
Old Jan 9, 2021 | 12:45 AM
  #338
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Initially you turn the star wheel until there is a slight drag
Old Jan 9, 2021 | 12:46 AM
  #339
Goshdarnram
I seen people spin the drum left and right Is that the way they tell drag by the resistance from the spin?
Old Jan 9, 2021 | 02:44 AM
  #340
MoparFanatic21
Correct you spin the drum and out would turn very easily
