Help with misfire and bogging down
Old Nov 29, 2020 | 07:18 PM
  #211
Goshdarnram's Avatar
Goshdarnram
Also nutral safety switch fixed my back up lights so heck yeah!
Old Nov 30, 2020 | 09:03 AM
  #212
Check the fluid after you drive it a bit. See if it is foamy.... Might just be some air left in the system.
The pull when you brake is likely a..... brake..... problem. You have a caliper hanging up, or a collapsed line. If your front soft lines are original, replace them, pull the calipers, check the pads, make sure the calipers more freely on the guides, etc.
Old Nov 30, 2020 | 01:40 PM
  #213
Goshdarnram
I noticed my pads where down a lot so I planned on putting new pads on it this weekend I was just wondering if I could have goofed it up when putting steering box in but I will definitely check out the calipers and all that this weekend the rotor itself on the passenger side looks pretty good on the driver side theres a few spots that have pitting in it the rotor itself looks straight I’ll have to send some photos when I pull them this weekend
Old Dec 2, 2020 | 01:38 AM
  #214
Goshdarnram
What would I upgrade the brake lines to?
Old Dec 2, 2020 | 07:04 AM
  #215
The nickel/copper lines are easiest to work with. Braided stainless soft lines firm up the pedal a bit. Several companies also sell complete kits for the hard lines in various materials. Just depends on what ya wanna do.
Old Dec 2, 2020 | 12:03 PM
  #216
Goshdarnram
Oh alright I might go with the braided lines if myn are having problems was looking at getting drilled and slotted rotors any advantages the rotors on myn look like they need changed soon
Old Dec 2, 2020 | 06:30 PM
  #217
On a stock truck, stock rotors are just fine. The drilled and slotted fellers are just for looks. You won't see any difference in braking, and the rotors are prone to cracking around the holes. Maybe on a track car they might be useful, but, for the street? Nope. Just a gimmick to extract money from your wallet.
Old Dec 2, 2020 | 07:56 PM
  #218
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You really think so? The 2500 I just bought has them (came with them) and I think it does brake better. But no real way to test that
Old Dec 2, 2020 | 09:49 PM
  #219
I think it has more to do with what pads you put on there, than the rotors.
Old Dec 2, 2020 | 11:10 PM
  #220
MoparFanatic21
I did get the ?Ceramic? fellers, the most expensive pads they had.
