Help with misfire and bogging down
Old Jan 9, 2021 | 12:24 PM
  #341
Goshdarnram's Avatar
Goshdarnram
Oh okay so you just feel for it?
Old Jan 9, 2021 | 01:07 PM
  #342
Yep. Although, if you have a limited slip rear, getting the adjustment right is a bit more difficult......
Old Jan 9, 2021 | 02:43 PM
  #343
Goshdarnram
I belive I do have the limited slip but I think I got it brake are a lot better now thank y’all again
Old Jan 9, 2021 | 05:55 PM
  #344
Goshdarnram
Hey I noticed that when I stopped sometimes after a few seconds I’d feel a thud coming from the rear not bad or anything but I’m curious if I messed the brakes up or if there adjusting them self’s or something the brakes stop fine and feel good
Old Jan 9, 2021 | 06:36 PM
  #345
Goshdarnram
Also I’m about to change rear diff fluid in the truck I belive it’s a Dana 70 rear and 60 in front it’s the 8800lb truck weight what all do I need to do the full job in both the rear and the front I’ve done in in a 01 Ram 1500 before but I don’t want to mess up and would like to know exactly what I need friction modifiers gear oil all of it would be greatly appreciated
Old Jan 10, 2021 | 10:26 AM
  #346
Same process as the 1500. Fluid choice depends on what you do with the truck. If you regularly tow/haul with it, 75W140 synthetic, if not, then 80/90 is fine. If you have LSD, I think it's four ounces of friction modifier in the rear. The front is open diff, so, doesn't need it. You can use gaskets, or RTV to reseal the cover, or both, if you so choose. (I just use RTV.....)
Old Jan 10, 2021 | 10:41 AM
  #347
Goshdarnram
Oh alright that sounds good to me I’ve rear online that the thump I’m hearing after a few seconds of stopped is gas in the gas tank lol? Sounds weired but that’s what I’ve heard I’m not sure if it’s true or not but I don’t haul to much
Old Jan 12, 2021 | 11:50 PM
  #348
Goshdarnram
Hey heater question I just replaced a 1997 Dodge Ram 1500 2wd heater core,thermostat,thermostat housing,water pump, new coolant flushed the system but the heat is still bad any ideas? Seems like there’s a lot of rust in the motor or brown stuff could be gelled coolant maybe I’m not sure but looks like rust it’s had a new radiator not to many years back any ideas how to get the heat to work better it sucks right now
Old Jan 13, 2021 | 10:09 AM
  #349
Try back flushing the heater core. See what comes out. If that still doesn't wanna work, pour some radiator flush into the heater core, leave it sit for a while, (or even maybe some CLR?) then back flush it some more.
Old Jan 13, 2021 | 10:24 AM
  #350
Goshdarnram
I flushed the radiator before I put the new heater core and thermostat in but only flushed for about 30 mins while running the engine I know the thermostat was covered in big rust flakes looks like they where stacked on it and when I had everything off I used water and flushed it out for as long until it turned clear both in the radiator and block what’s clr?
