Help with misfire and bogging down
Old Sep 15, 2020 | 07:50 PM
  #41
Goshdarnram's Avatar
Goshdarnram
Lol alright will do tomorrow for sure! Thank you very much!
Old Sep 16, 2020 | 05:55 PM
  #42
Goshdarnram
This is what I found
Old Sep 16, 2020 | 05:56 PM
  #43
Goshdarnram
The gray wire heading into the square block has vaccume before it goes into the block but I blew the block out tried it in 2wd and 4wd I don’t get vaccume coming from the block at all the passages are clear on the block any ideas?
Old Sep 16, 2020 | 06:21 PM
  #44
Probably one of the lines is broken, or rusted out..... If you disconnect the lines where they come from the t-case switch, to the metal lines that run forward, do you have vacuum there?
Old Sep 16, 2020 | 06:22 PM
  #45
Goshdarnram
Nope after the gray/white wire goes into the block square thing nothing after that has vacuum
Old Sep 16, 2020 | 06:25 PM
  #46
Wonder if the switch itself has gone bad.
Old Sep 16, 2020 | 06:27 PM
  #47
Goshdarnram
I’m not sure I blew threw the square thing and I could blow threw it it’s all rubber is there anything beneath that?
Old Sep 16, 2020 | 06:28 PM
  #48
There should be a 4 port vacuum switch on top of the tcase, right by the shift linkage. That is what it is supposed to hook to. Keep in mind, it is keyed, and has to go on in the correct orientation.
Old Sep 16, 2020 | 06:30 PM
  #49
Goshdarnram
Yup pulled it off blew threw it out it back on the correct way and nothing was happening from the white wire to the switch had vaccume but from the switch to anything else nothing
Old Sep 16, 2020 | 06:32 PM
  #50
Pull the switch out, see if you can operate it manually. (they like to rust up, and jam.....)
