Help with misfire and bogging down
Old Sep 16, 2020 | 07:52 PM
  #61
It just unscrews. Standard right-hand threads. Deep socket? Channel locks? I think chemicals might be a good idea too...... Clean it off up there good before removing it though. Don't want all the crap that accumulates up there getting inside the t-case.
Old Sep 16, 2020 | 07:55 PM
  #62
Goshdarnram's Avatar
Goshdarnram
Gotcha I think it’s a 1 1/8 thread
Old Sep 16, 2020 | 08:50 PM
  #63
Goshdarnram
I ordered it it’ll be here the 22 I’ll get them o2 sensors this week so hopefully one step out at a time
Old Sep 19, 2020 | 06:28 PM
  #64
Goshdarnram
Pulled the battery cable to reset code and put them ntk o2 sensors in it runs and drives even better it feels like it’s got the power it was lacking so far only drove it about 15-20mins and it’s driving good! Taking it for a 2hour drive tonight will keep you updated wish me luck! The vacuum switch will be here Monday still haven’t got the old one off lol
Old Sep 21, 2020 | 02:28 AM
  #65
Goshdarnram
Hey if you don’t mind me asking the last issue I’m away of on the truck is when I turn left it has no power steering it doesn’t whine or anything but it just doesn’t turn easy at all if your not rolling it’s almost impossible but turning right is supper easy as it should normally be any ideas are greatly appreciated thank you
Old Sep 21, 2020 | 08:27 AM
  #66
Valving in the steering box itself handle that job. You might be able to flush it out, and solve it, or, you may need to replace the box.....
Old Sep 21, 2020 | 11:28 AM
  #67
Goshdarnram
Oh okay yeah that makes sense the guy I bought it off of said he put a new box in it but didn’t bleed it I honestly didn’t they it would affect it that much just from air in the lines I think maybe it wasn’t replaced
Old Sep 21, 2020 | 11:41 AM
  #68
A lot of the time, the 'replacement' box you get from the parts store has more problems than the one it is replacing..... Borgeson, and Redhead make rather good replacements, but, they are a bit pricey. There is also Blue-Top, but, last I checked, they didn't have any in stock for our trucks. Keep in mind, there are two possibilities for your steering box, only difference between them is the steering ratio.
Old Sep 21, 2020 | 12:27 PM
  #69
Goshdarnram
Oh okay do you mind sending me a link to what box I would need I looked them up but I’m not sure what some of them mean
Old Sep 21, 2020 | 02:26 PM
  #70
This one is the 15:1 ratio, makes for more responsive steering, the 18:1 box is used on the heavier duty trucks apparently.
