Build 3605.9
Old Sep 17, 2020 | 11:03 AM
ThatRedRam's Avatar
ThatRedRam
Default Build 3605.9
Im building a Dodge 360 5.9 Computerized for my 95 dodge ram. Im wanting to get forged pistons along with the whole ratating assembly without spending 1000 or more. Any recommendations?
Old Sep 17, 2020 | 11:08 AM
ThatRedRam's Avatar
ThatRedRam
I need forged pistons, rods, crank, rings. just everything in the rotating assembly that will fit a 95 dodge 360 magnum.
Old Sep 17, 2020 | 11:09 AM
ThatRedRam's Avatar
ThatRedRam
Im also wanting to get bigger pistons so i know ill have to have the cylinders bored
Old Sep 17, 2020 | 11:10 AM
Even the stock bottom end is pretty stout, any particular reason you want to go with forged? They ain't cheap..... as you have noticed.
Old Sep 17, 2020 | 11:23 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I agree unless you are building a high HP motor or tons of boost no reason for forged pistons
Old Sep 17, 2020 | 11:29 AM
ThatRedRam's Avatar
ThatRedRam
wanting a good bit of horsepower and planning on maybe boosting in the future. looking to make 400-500 hp right now
Old Sep 17, 2020 | 11:51 AM
ThatRedRam's Avatar
ThatRedRam
ill probably just go with hypereutectic pistons
Old Sep 17, 2020 | 02:07 PM
Big difference between building a normally aspirated motor, and a blown motor. Pick one, and stick with it, otherwise, you get to spend a bunch of money twice.
Problem with the 5.9 is though, without boost, sure, you can get 400 hp out of it, but, it will all be in the upper RPM range, rendering it pretty much useless as a truck motor. If you want to go with NA, build it for bottom end to mid range torque. You will be much happier with your truck.
Old Sep 17, 2020 | 11:01 PM
ThatRedRam's Avatar
ThatRedRam
well i wanna get it ready for boost. I wanna get hypereutectic pistons. but idk what pistons and rods to get exactly could somone put links to some?
Old Sep 17, 2020 | 11:09 PM
MoparFanatic21
Rods you want thicker forged H beam. Pistons you will need pistons designed for boost as the top run is down farther and they are thicker in key areas. Plus heads, studs, crank you will be probably into $3000 for all that. Not including heads
