Compressor Oil
Old Oct 8, 2020 | 01:38 PM
93 ragtop's Avatar
93 ragtop
Default Compressor Oil
Could someone tell me the weight or type of PAG oil used in a 2000 Ram? Also, could you tell me the total oil capacity of the system?
I appreciate the help.
FWIW Its a rebuilt compressor, on a 2000 engine, going in a 87 dakota.
Old Oct 8, 2020 | 02:32 PM
I was gonna say it's on a tag, under the hood, but, that ain't gonna work for you.
From the 01 service manual, looks like 6.2 ounces of SP 20 PAG oil.
Old Oct 8, 2020 | 04:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The total oil capacity is for a completely new system. Most compressors have oil in them
Old Oct 8, 2020 | 06:23 PM
Moparite's Avatar
Moparite
An 87 is for R12 refrigerant and the one you have is for R134. The systems use different oil!
Old Oct 9, 2020 | 10:51 AM
93 ragtop's Avatar
93 ragtop
Thanks, that is the info I need!!
FWIW, I kinda got a curve ball thrown at me.... In the beginning, I figured, I would flush and be using the ester based oil, since the 87 has a mineral oil (R12) (basically a 134A retrofit)
Well upon receiving my new compressor, it came with 3oz of PAG oil inside.
The instructions said, if additional oil is needed, use what the vehicle recommends....
I really did not want to use PAG due to it being incompatible with other oils, and being concerned that all is out of the evap. condenser, etc.
But I have no choice, just flush real well!!
Thanks again, for the type of PAG and volume.
Old Oct 10, 2020 | 08:23 AM
Moparite's Avatar
Moparite
You should replace the receiver/drier, This is where most of the oil stays.
Old Oct 11, 2020 | 07:47 AM
93 ragtop's Avatar
93 ragtop
Always replace the drier anytime a system is broke down..... Will only be reusing the evap, lines, and condenser.
