2002 Ram 2500 5.9 Magnum P0308 code
Old Dec 1, 2020 | 03:12 PM
Nick Crabtree's Avatar
Nick Crabtree
Default 2002 Ram 2500 5.9 Magnum P0308 code
I’m trying to figure out how to diagnose the code. I have checked plugs and wires which are good. Compression is good. No oil inside the plenum and it doesn’t appear to have hesitation or rough idle. At least not that I can tell. Not sure what else to check. Any ideas would be greatly appreciated.
Old Dec 1, 2020 | 07:43 PM
Cap and rotor would be my next step.
Moving this to second gen ram section for ya. Welcome to DF!
Old Dec 1, 2020 | 08:29 PM
Nick Crabtree
thanks. Forgot to mention I checked cap and rotor and also cleaned injectors
Old Dec 1, 2020 | 08:47 PM
Swap injectors on six and 8, see if the miss moves with the injector.
How's your cat? Usually, if the cat is starting to plug up, cylinder 8 has issues first.
Old Dec 1, 2020 | 09:35 PM
Nick Crabtree
I replaced O2 couple months ago and just recently replaced muffler. Entire exhaust is severely rusted. Didn’t think it would throw a misfire code so never thought about the cat
Old Dec 2, 2020 | 07:06 AM
What brand O2's did you install?
Old Dec 2, 2020 | 07:19 AM
Nick Crabtree
they are NTK Brand. Replaced them back in August of this year
Old Dec 2, 2020 | 07:20 AM
Ok, those should be good.
Is it only cylinder 8 that's spitting a code?
Old Dec 2, 2020 | 08:27 AM
Nick Crabtree
Yes. I tried swapping plugs but it didn’t change anything. I’ll try swapping injectors this morning and see if that makes a difference
