Alternator Upgrade Help
Old 01-03-2021, 10:35 AM
FiveNine Motorsports's Avatar
FiveNine Motorsports is offline
I do believe they are 'on demand' type alternators. I.E. If it doesn't need to, it doesn't put it out. Of course, I have been wrong before....... They have a variety of different outputs available. Get one that will meet your needs, and not empty your pockets. Be sure to upgrade the feed wire from the alternator, to the battery, and also the fuse in the power distribution center.
I appreciate all the help bro, i definitely have some more options now and might have to do some experimenting. Glad to see you're still active after all these years helpin everyone out
Old 01-03-2021, 10:39 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
I really need to get a life. I missed the last sale at Meijers. I tried mail order, but, that just didn't work out very well.
Strangely enough, I actually consider participating here, "Fun". Make me use my brain once in a while. God knows it needs the exercise.
Old 01-03-2021, 01:06 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Lightbulb
I find a bunch of 'em on Amazon..... Have a look at this one.
Nice research! I had a feeling that high output alternators that fit into the stock configuration were available for 2nd gen trucks.
Old 01-04-2021, 06:50 AM
Moparite's Avatar
Moparite
Moparite is offline
There is a limit that you can go to (i believe 150) Anything over that you need to use a different fuse holder. The stock type fuse only will go up to that amount.
Old 01-04-2021, 10:44 AM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
If the Little fuse fits her can buy a 250 amp one there
Old 01-04-2021, 11:03 AM
AtomicDog's Avatar
AtomicDog
Is that a possible fire hazard without upgrading the wiring/connector?
Old 01-04-2021, 11:11 AM
HeyYou is offline
Definitely need to upgrade the wire from the alt, to the PDC.
Old 01-04-2021, 05:19 PM
MoparFanatic21
The wiring yes
Old 01-04-2021, 06:25 PM
Moparite's Avatar
Moparite
Moparite is offline
I forget what amp fuse it was but it tops out at certain amperage and you need to get a different fuse holder/fuse and probably cable also if you plan on going more than that.
Old 01-04-2021, 10:00 PM
MoparFanatic21
I was talking about putting a fuse between the two power wires
Quick Reply: Alternator Upgrade Help
