my 2001 ram 1500 5.2
Old Feb 22, 2021 | 04:15 PM
Ramman18's Avatar
Ramman18
The T-case only takes a little over a quart. Use just plain ATF.
The trans takes only synro friendly manual trans oil - Mopar brand or Valvoline syncromesh. The drain plug on the bottom of the trans is for the trans. The fill plug is on the passenger side body of the trans. The plugs on the T case you already know. Completely different component.
If you want to go further, the rear diff uses 80w90 and the front 75w90. If limited slip, must add friction modifier.
Old Feb 23, 2021 | 04:13 PM
colehart's Avatar
colehart
Default fluids
i used atf +4 in the tcase. what should i use in the tranny? the tcase fluid was dark as night. glad i changed it. also thanks on the recommendations on the clutch kit. i got the 12in and it went in perfect and feels great.
Old Feb 23, 2021 | 09:26 PM
Ramman18's Avatar
Ramman18
That's fine. Like I said, only use Mopar Manual Transmission fluid or the Valvoline Syncromesh in the blue bottle.
Old Feb 23, 2021 | 11:06 PM
colehart's Avatar
colehart
how many quarts does it take to fill tranny?
Old Feb 24, 2021 | 02:05 AM
Ramman18's Avatar
Ramman18
Just a hair over 2 quarts. Get three and squirt in till it runs out the fill hole. The Mopar fluid is part #4761526
Old Feb 26, 2021 | 07:56 PM
colehart's Avatar
colehart
what performance chip do you guys recommend for my 01 ram 1500?
Old Feb 27, 2021 | 01:38 AM
armynurse's Avatar
armynurse
I'm running a Hemifever tune in my truck. It makes a little bit of a difference - I wouldn't say a lot on an essentially small stock 5.2 engine trying to move a big full-size 4x4 truck. I have the auto trans, and it changed the shift into OD from 45mph to 55mph which helps. Changing the gearing from the factory 3.55 to 4.10 when I went to the 33" tires helped too.
You asked about the largest size tires you can fit on your truck without a lift. You can actually raise the truck 2" very easily (and cheaply) with a 2" taller spring up front (I used Skyjacker springs), and a 2" add-a-leaf in the rear (I used a long-leaf add-a-leaf). With just a 2" lift, I wasn't concerned about an adjustable front track bar. Here's my truck with the 2" lift and 285/75/16" (33") tires. 295's would fit just fine too (and would look nice). I was tempted to lift it higher and go with 35" tires, but the largest spare that will fit under the bed in the factory position is a 33" tire. And as it is, with my current set-up it is still a little bit of a stretch for me to get into the seat (and I'm 6' tall).
Old Feb 28, 2021 | 07:07 PM
colehart's Avatar
colehart
Default trucks stalling not accelerating
its a 96 or 97 ram 1500 5.9. the truck wont go faster then 20mph and wont accelerate. does any one have an idea of what it could be? he replaced the fuel pump thinking that might be the problem but its not. any ideas?
Old Feb 28, 2021 | 07:25 PM
Clogged cat.
Old Mar 2, 2021 | 12:53 AM
armynurse's Avatar
armynurse
Does it buck and such when trying to go faster than 20mph? If so, seems like one of the sensors might be the culprit (I had it happen to me, but I forget which sensor). It was one of the ones on the throttle body. I'm sure someone will chime in.
