Fuel pressure drops in real time
Old 01-23-2021, 04:30 PM
Steve1098's Avatar
Steve1098
Steve1098 is offline
Default Fuel pressure drops in real time
My 2000 ram 2500 has always taken a bit too long to start due to fuel pressure taking too long to build up. I normally prime it 3x by putting the key in and putting to ignition first. I hooked up pressure guage on the fuel rail, and heres what i got. So If i put the key in and turn to ignition to hear the fuel pump turn on , the gauge needle jumps to 25psi. I then turn the key back off, and then back on to ignition only again, where this time it jumps from 25 to about 40ish psi. If i do it a 3rd time, it remains around that area like it should. Keeping the key to the ignition location i am able to watch the gauge needle drop in real time..kinda fast (which makes sense why it takes long to start each time). When truck engine is on however, there isnt a problem (shifts and accelerates just fine with or without a load in bed). I was going to replace the pump, but is there something else i can check for a leak first? The fuel pump sounds healthy, but obviously there is a leak somewhere either injector or inside the fuel pump?
Old 01-23-2021, 05:38 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,224 Likes on 2,974 Posts
You should be seeing closer to 49PSI after the third key on. You have a failing pump.
Old 01-23-2021, 07:52 PM
Steve1098's Avatar
Steve1098
i think it was 45 but i'll double check tomorrow (i was just rounding off)
Old 01-24-2021, 08:02 AM
Moparite's Avatar
Moparite
Moparite is offline
You should get to the 4# psi(should read 49 psi) on the first key on. Replace the pump and see if you still have the dropping pressure.
Old 01-24-2021, 02:22 PM
Steve1098's Avatar
Steve1098
Well sure i could do that, but it could be something before that where the leak is. Dont wanna drop the tank and replace the pump until i have to. Was looking for suggestions for other possibilities
Old 01-24-2021, 04:21 PM
HeyYou is offline
If you aren't seeing gas on the ground, then any leak/problem you have is going to be with the fuel pump module itself. It is replaced as a single unit, so, changing out the pump, will solve your issue. Delphi or Denso pump only please. Unless you like changing them....
Old 01-24-2021, 05:01 PM
Steve1098's Avatar
Steve1098
Sounds good. Also i checked it again and the first key turn was 20psi. 2nd key turn built up to 45psi but almost instantly drops. Truck engine actually running stays at 45psi
Old 01-24-2021, 07:27 PM
HeyYou is offline
So the pump is just getting weak, and the check valve has failed. (not unusual.....)
The following users liked this post:
Steve1098 (01-24-2021)
Old 01-24-2021, 07:59 PM
BigRedRam95's Avatar
BigRedRam95
BigRedRam95 is offline
How long should it hold pressure? Mine only holds for about 10 min. It backs down to about 10 psi and hold it there for a long time. But no problem starting
Old 01-24-2021, 08:22 PM
HeyYou is offline
Pretty sure there is a spec for it in the service manual, but, so far as I am concerned, so long as it doesn't immediately drop like a stone when the pump stops, and it actually gets above 40PSI at the initial key turn, its all good.
Quick Reply: Fuel pressure drops in real time
