Flakes in transmission pan
I have this pan but mine is older and doesn’t have the temp sensor bung and it’s silver not black.
I used this just in case.
I got a filter from auto zone and the fluid is super tech atf+4 from Walmart $5 a quart is the best price I could find.
https://www.amazon.com/Derale-14210-.../dp/B004XONSYE
https://www.amazon.com/gp/aw/d/B07SR...?ie=UTF8&psc=1
it was almost 4 days before I put the new filter and pan on. Plus I did the check valve delete so that might have let a little bit more out. I’m going to go get 4 more qts tonight and see how much more it takes to get it full.
It took another 3 quarts and it’s still shows a little low but in the safe while running in Neutral after shifting through the gears. My driveway is a little sloped to the road so I’m going to back it out on the level tomorrow and recheck and finish topping it off. I sure didn’t think it would take 11 quarts to fill it.
