Head upgrade
Old Feb 22, 2021 | 12:30 PM
  #31
O Hen's Avatar
O Hen
Called Hughes, got a price on everything except injectors, they want 350 for 8 injectors. I thought the stock or maybe 2 port injectors would be fine, he said they wouldn't put enough fuel in at high rpms. Said i "shouldn't" have to drill and tap anything for sensors or water fittings. Said I'd have to have additional work done on aluminum heads, as well as different pistons in order to get the compression i need for the engine to perform at it's best since the actual compression is 8 to and not 9 to as advertised.
Old Feb 22, 2021 | 10:34 PM
  #32
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Do not get a tuner from them!
Old Feb 23, 2021 | 06:39 AM
  #33
O Hen's Avatar
O Hen
Okay👍
Old Feb 23, 2021 | 08:29 PM
  #34
MoparFanatic21
Okay👍
Seriously I waited almost 4 months to get it from them. Better off to get one from flying Ryan. They use PIA and there tunes aren't great
Old Feb 23, 2021 | 08:33 PM
  #35
O Hen's Avatar
O Hen
I will probably get the intake and throttle body from them for sure. Everything else I'm thinking I'll search for. Felt like he was trying to sell me everything in the world. Tried to get me to buy a $130 cam insert tool. I thought with grease and very carefully it was no big deal to install a cam without damaging it.
Old Feb 23, 2021 | 08:43 PM
  #36
Correct. I will screw a long bolt into the cam to use as a handle when installing it.
Old Feb 23, 2021 | 08:47 PM
  #37
O Hen's Avatar
O Hen
Does the crank need to be turned with the notch middle of top?
Old Feb 23, 2021 | 08:49 PM
  #38
Crank shouldn't interfere with installing the cam..... once you have the cam in there, just set up the dots on the timing gears, and install the chain.
Old Feb 25, 2021 | 01:32 PM
  #39
O Hen's Avatar
O Hen
Should i advance the timing?
Old Feb 25, 2021 | 03:28 PM
  #40
No. The computer will get confused.
