Transmission cooler lines issues !
Old Mar 13, 2021 | 08:40 PM
96albertaram's Avatar
96albertaram
Default Transmission cooler lines issues !
I'm done getting stranded! This is the 3rd time this ***** setup has failed. The hose is coming off the fitting ever so often with these stupid screw clamps the last owner had. Has anyone beefed up these lines to prevent this? Has anyone done braided lines and can you send me some ideas. I want a permanent fix.
Old Mar 13, 2021 | 11:29 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
They is suppose to be crimped. If it is coming off you can flair the metal line to prevent it but they aren't suppose to be under that much pressure
Old Mar 13, 2021 | 11:56 PM
96albertaram
this is the hose that keeps coming off going to the cooler itself. I m curious if a guy could get a kit with a new aux cooled with an fitting that just go right to the factory metal lines and delete all this garbage
Old Mar 14, 2021 | 10:48 AM
What's on the end of that fitting? If it is smooth plastic line, then clamps are never going to stay on. If it's metal line, as the Fanatic said, flaring the end of it, and then clamping it in place will solve the problem.
Another option would be to get some unions, flare nuts, and the appropriate size steel line, and graft in a metal line there, or at the least, hose barbs.
Old Mar 14, 2021 | 11:04 AM
96albertaram
when the line slipped off that fitting is smooth. Not even barbed..
I almost want to re do the whole thing. Including the trans cooler that has actual fittings on that. Then braided lines to wear it meets the metal transmission lines. No clamps anywhere! Lol I'd have to do some searching to find the right gear
Old Mar 14, 2021 | 11:17 AM
Summit has some interesting stuff.... Might dig thru that, see if you find what you want.
Old Mar 14, 2021 | 11:18 AM
96albertaram
Ya ill take a gander. Truck is not moving till its fixed
Old Mar 16, 2021 | 11:48 PM
96albertaram
ended up upgrading my setup. No more hose clamps!!
Old Mar 17, 2021 | 07:03 AM
There ya go. That's pretty much what I was thinking.
