R46h Rebuild
Old Nov 7, 2021 | 11:04 AM
  #141
What I am seeing is, Orange/black trace wire, on cavity three. With the connector facing you, latch on top, it will be the rightmost wire.
Old Nov 7, 2021 | 11:22 AM
  #142
Letsfixit's Avatar
Letsfixit
Okay....this is what the manual has... I'll follow your instruction and hope it's white on top too. If not I'll snip it and see. I'M HOPING I KEEP 4TH GEAR..TY. Okay I gotcha orange blk trace
Old Nov 7, 2021 | 11:25 AM
  #143
That's the internal wiring. I suspect the external wiring is not the same color.
Old Nov 7, 2021 | 11:26 AM
  #144
Letsfixit's Avatar
Letsfixit
Yessir I gotcha orange blk trace. I'm going to shoot you a photo of what I got before I snip it.
Old Nov 7, 2021 | 11:43 AM
  #145
Letsfixit's Avatar
Letsfixit
Yes sir is the wire on the right orange black Trace transmission guy said it would be the one on the rear so that's toward the rear also so I'm going to snip it. I'LL LET YOU KNOW WHAT HAPPENS BECAUSE IF IT WORKS OUT I'VE GOT ONE MORE QUESTION.
Old Nov 7, 2021 | 12:20 PM
  #146
Letsfixit's Avatar
Letsfixit
ABSOLUTELY PERFECT...... Now the big QUESTION....I should be able to take those wires and put them to a TOGGLE SWITCH inside the cab for those rare times I do get over 60as a cruising speed. Is that a DO'ABLE thing?
Old Nov 7, 2021 | 02:54 PM
  #147
Yep. Just use the switch to complete the circuit (re-connect the wires) and the PCM will handle the rest. You do NOT want to have the switch enable TCC on it's own, that would make stopping quickly problematic.
Old Nov 7, 2021 | 08:13 PM
  #148
Letsfixit's Avatar
Letsfixit
Understood...ty again.
Old Nov 18, 2021 | 10:16 AM
  #149
Letsfixit's Avatar
Letsfixit
I'm going to ask a question in the most UN-CONFUSING way I can... I understand that LOC-UP puts the train 1 on 1, and in an NO LOAD state I can see it picking up the 2 WEAK CYLINDERS and causing the SHAKE (@ 60mph an below). However, in a NO LOAD state (cruise/coasting more-less), @ 60mph or more, WHY does it run SMOOTH?? SECONDLY.. when in 4th gear, under the same NO-LOAD type situation, low or high rpm, you can't make it SHAKE or even vibrate ???
IT'S ONLY IN LOC-UP, FOOT ON GAS, OFF GAS, IN A LOAD, NO LOAD...UNDER 60MPH IT SHAKES. AND LOWER THE SPEED THE WORSE THE SHAKE.
(Since I installed the switch however, it's been amazing)
Old Nov 18, 2021 | 10:48 AM
  #150
The vibration you feel is the weak cylinders. Under no load, very little of that vibration is transmitted thru the drive line. Under load, you should feel it, it should be even more pronounced in O/D.
