IOD Fuse Blows
Didn't disconnect them but I did disconnect the connector they all run to (other then under hood lamp but you have to disconnect the main connector which means no power coming to it). I'm at a complete lose. Can't disconnect the 3 connectors without pulling the dash no way to press the release button
I am excited as I like everything factory! So I pulled wires out of another dash harness (have to order striped wire and I'm impatient) and ran them with the factory wiring. Only two things bug me and I'll probably end up pulling the dash again is, I had to use different color wire on 3 wires and I don't have the factory connector to use by the bulkhead connector so I used one of my Deutsch Connectors and they really bothers me .While I was in there I reran my wires for the 4th gen mirrors, added two more Deutsch Connectors (one by the door so if I ever have to pull the door off and one by the bulkhead connector). I should have pulled the passenger visor in the beginning but I thought "No way that's the problem" live and learn .
Now I just have to paint the truck, figure if I want to do a shackle flip (to get some rake back), replace the kicker (JUNK!!!) rear speakers, adjust the doors so they actually seal, charge the AC, and fix the rear door cables.
The only thing that worried me pulling the dash was having to get the remote start reprogrammed but I downloaded the manual and did it myself. Anybody who has a Computer remote start everything will work but to program the remote start, you have to program the Tach Signal. To do that start the truck, hold the brake and press the remote start for 3 seconds. If you did it right the truck will flash the park lights once and honk once
