Both Sides Power Windows and Mirrors Stopped Working
Power Lox work on both sides but not windows and mirrors. First, windows were only working when truck was running then they stopped working altogether then started working next day after starting truck during entire drive but since that ride, they have not worked at all.
Problemz all started when I disconnected negative battery cluster to battery for 15 mins then reconnected, I was simply doing this cuz I had chgd out my iac valve.
The following users liked this post:
Vince Adelman IV (05-26-2021)
Check your driver side switch the wires were it connects wire to pong if it's broke just weld it back together
The following 2 users liked this post by Moparla360:
Kayden Barrios (06-01-2021),
That wld be great, if u have a vid. Ign/acc fuse under hood n circbrkr on dash side loI t be fine. Wires all look to be fine at prong dir under pwr window switches on door side. Mirr switch also does not work so gotta believe it is sthing at door jam. Trying to find which wires and what to test for, at door jam.
