98 1500 5.2. Pcm 920 921 999 codes on self check
Old Jun 5, 2021 | 10:06 AM
ghyatt76's Avatar
ghyatt76
Do the fuel pump and ASD relays click when you first turn the key on?
no clicking
Old Jun 5, 2021 | 11:17 AM
Verify you have power TO the pcm. I think there are a couple fuses for it, both in the PDC, and in the Fuse block on the side of the dash.
Old Jun 5, 2021 | 04:35 PM
ghyatt76's Avatar
ghyatt76
ok so I checked fuses all good there is power going to the Engine Inline plug I was trying to find power wire for pcm but the link for my service manual is not working
Old Jun 5, 2021 | 06:01 PM
Clicking on the link for the manual, should open a new tab with a direct download of the PDF file. (it will open in that tab.) Give it a bit, it *should* work. (works for me....)
Old Jun 6, 2021 | 07:56 PM
true blue's Avatar
true blue
I would also check all engine, body and frame grounds.
Old Jun 7, 2021 | 02:45 AM
ghyatt76's Avatar
ghyatt76
Default Figured it out
So turns out I didn't do a good enough inspection. My ground coming from the battery had come on contract with the exhaust manifold so thanks to everyone y'all are awesome
Old Jun 8, 2021 | 12:22 AM
Cindy Tyler's Avatar
Cindy Tyler
Default 1999 dodge neon ALARM IFF/NO SPARK
Originally Posted by ghyatt76
no fuel pump prime or spark
no spark fuel pumps sounds come on almost starts NO SPARK WHAT 2 DO? TY
Old Jun 8, 2021 | 07:17 AM
Cindy, you really need to give us more info than that. What are you driving? What troubleshooting have you done? Are you even posting in the right section? If you are working on a Neon, you need to post in the Neon section, posting in the Truck section isn't going to get you any help, as we don't know squat about Neons.
Old Dec 4, 2021 | 12:49 PM
DodgemcDirtyMax's Avatar
DodgemcDirtyMax
Hello, I am having the same issues. However, at the end the truck doesn't show the "no bus". Would you know anything about that?
Thanks
Old Dec 5, 2021 | 10:45 AM
Thanks
Start a new thread, tell us what you are driving, year, engine, etc, and what the actual problem is.
