96 dodge V10 engine swap, in Alaska, I got it run n
Yeah, I pulled the fuel rail and brought it down to the boat when I had the engine out and soaked it in diesel. i bought another fuel rail and fuel line when I was in Seattle. i cut the fuel line in half so I could flare the ends and install a real fuel filter! plus it had to be cut in order to ship it on my barge load.
Gonna replace the pump and clean the tank. if it still runs like crap I will bite the bullet and pull the rails. plus I will clean my old injectors in the process! Baby steps I guess!?
Yeah, I am real curious who thought it was a good idea to hide a good chunk of the engine back underneath the cowl...... Makes workin' on 'em difficult, to say the least.
Have to lay on top of the engine to get at the back plug on the driver side! Those headers dont make it an easier either. Almost burned thru my heater hose yesterday after the plug wire and coil pack swap! Glad I was standing there for the initial start up. Smelled plastic and rubber almost instantly! nothing a few black tape wraps couldnt fix!
Changed fuel pump and cleaned out the tank. holy you know what! there was atleast an inch of water in the bottom of the tank and dirt for days! Busted out the generator the shop vac and a few 5 gallon oil buckets and made short work of it! We dont drop tanks in Alaska! We just get the cut off wheel out and cut access holes in the bed to get to the top of the fuel tank! so much easier this way! So $334 later, have a new fuel pump and 35 gallons of fresh supreme unleaded!
I think my sluggish feeling of lack of power is the transmission? When I take off in drive, it feels like the tranny is maybe slip n? but when I take off in first gear it seems to get with it on demand! reverse seems snappy too! so my guess is the band on the drive gear is pretty loose or wore out? I will buy a fuel pressure guage tomorrow when I return the fuel pump! Easy access and the fastest pump I know of, THE HANDY SHOP VAC!
Kinda nice to have an engine that holds all its fluids! Its like a brand new truck! 204$ for a years worth of insurance and the DMV is shutdown so I dont have to worry about license tabs! (Been expired since Mar2020)
Nice to be back on the road! We shall see how long she continues to run with this engine swap! Fingers are crossed, for sure! cheers ya'll! should be some new problems to discuss once I start put n some miles on the odometer!
So 2 weeks into the donor engine running, I still have the same issue? On the cold start in the morning engine fires right up and idles great. About 45 seconds after starting it. The engine starts to idle rough, you can hear it start to suck more air and the exhaust is rich, makes your eyes burn. So, if I used all my original sensors and the donor engine has the same issue, could one assume it has to be one of the sensors? like a mass air flow or an air intake sensor? Lord knows I have changed almost every sensor on this truck before the old engine failed! The mystery continues...........
