97 dodge ram 1500 5.9L NO HEAT
I have a 97 Dodge Ram 1500 4x4. Just replaced the heater core, thermostat and I still have no heat. Blower motor works well. Once up to temp no heat, I checked the lines going to and from the heater core. Both hot and I just can't seem to figure out what it is. All info is appreciated
Check the blend door coupling.
https://heatertreater.net/dodge-ram-95-02
I would verify that the blend door is still intact, and moving properly though.
The following users liked this post:
Keith_L (10-31-2021)
I've also kinda thought Heater Treater's info is a bit misleading. They clearly say '95-02 but aren't ALL Rams cable until '99 or '00? The '98 I service is also cable.
I mean their product is otherwise fine but it doesn't instill confidence in their tech info if basic info like model years is so far off.
Or maybe some Rams got the electronic blend as early as '95????
Trending Topics
