00 which side is the PCV Valve supposed to be on
Old Nov 9, 2021 | 08:43 AM
comet424's Avatar
comet424
Default 00 which side is the PCV Valve supposed to be on
which side is the PCV vale supposed to be on?
i watched the videos it talks about pass side.. mine wasnt.. mine is driver side goes into the plenium the other side (pass side) is a different style and goes directly into the air cleaner
is that wrong right? does it matter?.. as i read about postive pressure etc.. so i confused which way its supposed to go then
or is it right on the driver sider pcv vavle and pass is a like an Elbow .. and does that albow need changing
Old Nov 9, 2021 | 10:02 AM
Ramman18's Avatar
Ramman18
My 99 is the opposite as yours but it doesn't really matter. As long as you have ventilation, you're fine.
Old Nov 9, 2021 | 10:36 AM
comet424's Avatar
comet424
oh ok.. i wasnt 100% sure.. and is that one going in the airbox from the valve cover. . is that just a straight elbow?
i was told to change the pcv valve sinec my oil pan at the front U shapped part blew out big rip.. but when i changed the the pcv valve it still moved but wanted to double check things
i thought maybe its supposed to have 2 pcv valves etc
Old Nov 9, 2021 | 12:33 PM
Ramman18's Avatar
Ramman18
WHAT??? Please be clearer and use better spelling/grammar.
Either side needs one (1) PCV valve (Mopar are best) and the other is an open breather elbow (parts stores have them) connected to the air box.
Old Nov 9, 2021 | 07:08 PM
comet424's Avatar
comet424
i stated
everyone says. the PCV valve is on the Passanger side only... mine is on the driver side
Old Nov 9, 2021 | 07:20 PM
95RAM360's Avatar
95RAM360
i stated
my 02 3rd gen (has 5.9) is on drivers side as well
Old Nov 9, 2021 | 07:29 PM
PCV switched sides several times over the course of second gen production. There is no "Wrong" side, so long as one side can get clean fresh air, and the other side with the PCV valve goes to a good vacuum source, the system works as it should.
Old Nov 11, 2021 | 02:00 PM
Keith_L's Avatar
Keith_L
I just had the airbox off a 2000 MY to replace t-stat and I also noticed PCV had moved the driver side
Old Nov 11, 2021 | 04:11 PM
true blue's Avatar
true blue
Adding my 3 cents worth...just add an oil catch can to the pcv line. You'll be surprised how much longer you can go without cleaning the throttle body or IAC.
Old Nov 15, 2021 | 09:26 PM
atc250r's Avatar
atc250r
Isn't it weird then that the large hose from the breather goes to the dirty side of the air box? Nothing clean about the air on the lower half of the air box.
