Running Tail lights not working
Old Jan 21, 2022 | 07:41 PM
Sinexay's Avatar
Sinexay
Default Running Tail lights not working
Having issues with my running tail lights not working. The brake light and reverse lights work.
edit: turn signals also work
checked fuses and relays and they are good
Truck slide off road on ice patch and there were 2 relays found on the ground when it happened and I haven’t pin pointed where they go to. I’m wondering if it goes to the tail lights or the trailer lights..
Any suggestions on where to start or where to look?
Old Jan 21, 2022 | 07:42 PM
Sinexay's Avatar
Sinexay
Truck is a 1998 Laramie slt 5.9 automatic
Old Jan 21, 2022 | 08:44 PM
Sinexay's Avatar
Sinexay
Anyone have the wiring diagram for the tail lights?
Old Jan 21, 2022 | 08:50 PM
AtomicDog's Avatar
AtomicDog
You can download and find them in the service manual here - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Jan 23, 2022 | 02:07 PM
Sinexay's Avatar
Sinexay
Default Tail light ground wire
Still scratching my head trying to figure out why the running tail lights aren’t working., where is the ground strap for the tail lights located?
Old Jan 23, 2022 | 03:21 PM
Sinexay's Avatar
Sinexay
Default Thinking out loud
Thinking out loud.. since I’m not seeing any power at the socket maybe it’s a power/hot wire issue instead of ground wire issue?
Old Jan 23, 2022 | 04:09 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
So neither tail lights work and you aren't getting power to them?
Old Jan 23, 2022 | 05:26 PM
Sinexay's Avatar
Sinexay
Thats correct. Neither of The running tail lights work, not getting power to them. although the reverse and brake lights work.
Old Jan 23, 2022 | 05:27 PM
What about turn signals? (I think they use the same bulb/filament as the brake lights....)
Have a trailer harness on your truck? Have a look at where the trailer harness hits the rear harness.
Old Jan 23, 2022 | 05:28 PM
Sinexay's Avatar
Sinexay
the turn signals work.
