1998 Ram1500 stalls when first put it in gear
Old Apr 22, 2022 | 02:21 PM
Tylersgreenmachine's Avatar
Tylersgreenmachine
Default 1998 Ram1500 stalls when first put it in gear
I have a 98 1500 with the 5.2l. When I first start it up and put it in gear I have to pretty much floor it to keep it from stalling once I put it in drive or reverse. Once I drive down the road a bit it’s fine and won’t stall out in gear. It almost seems like it’s starting in too high of a gear.
Old Apr 22, 2022 | 02:52 PM
What gear it starts in shouldn't matter. It should not stall in gear. Might try cleaning the throttle body first. See if that helps.
Old Apr 24, 2022 | 01:21 AM
master tech's Avatar
master tech
Site Moderator & Tech
It more likely the torque converter locking up and this will cause the engine to stall in either reverse or forward gears. Is the check engine lamp on for a transmission code?
Old May 16, 2022 | 01:26 PM
Tylersgreenmachine
no there is no lights on or codes. I can get it to move if I rev the hell out of it then as it goes it dies off like as if it were a manual and you started in too high of a gear
Old May 16, 2022 | 01:27 PM
Tylersgreenmachine
I don’t think that would be the problem. The engine runs fine except for when you put it in gear it stalls out
Old May 16, 2022 | 04:04 PM
Cleaning the throttle body is free. (well, ok, a two dollar gasket....) They are notorious for gunking up, especially around the IAC well, so, the computer can't control the idle as well as it would like.
Old May 17, 2022 | 08:26 AM
Tylersgreenmachine
I see what you’re saying now. When it gets put in gear it can’t regulate the idle with a load
Old May 17, 2022 | 11:59 AM
Correct.
