Shifting Funny
Old Jul 17, 2022 | 03:20 PM
I"m Ike's Avatar
I"m Ike
Default Shifting Funny
My 2001 Ram 2500 Diesel has 80k miles. I just realized that it had been 2006 since the last transmission service. It had started shifting oddly so I took it to AAMCO and the flushed and changed the fluid and filter. However, still doing it. At around 40-48 mph it shifts rapidly up and down. Slower or faster it's OK. Should I try an additve? Is this and indication of internal failure? Old fluid was dirty, but no evidence of particles in it or the old filter. Appreciate all help.
Old Jul 17, 2022 | 03:34 PM
No additives thankyouverymuch. Is the tach just bouncing about 200RPM or so? If so, replace the throttle position sensor.
Old Jul 18, 2022 | 12:02 AM
95RAM360's Avatar
95RAM360
Mine did the hang up between 2 and 3 and at 45 it would go back and forth. Simple tv cable adjustment cured that but I have a 1500 gas with a 46re trans
Old Jul 19, 2022 | 07:25 AM
dodgetruck2's Avatar
dodgetruck2
The TV linkage ect should be about the same as gasser set up
If you have a DVM check the batteries with the truck running for AC voltage, if there's anything significant, say over .1 ACV I would suggest an alternator replacement, don't have it tested, its probably charging just fine and will pass a bench test, but it has a leaking diode letting AC voltage into the electrical system causing erratic sensor readings, in result poor shifting
Old Jul 24, 2022 | 08:40 PM
I"m Ike's Avatar
I"m Ike
Default Tsp
I replaced the TSP with no change. One shop I talked to said it sounds like the torque converter. I just had the fluid flushed at AAMCO and it didn't do this on the test drive before or after. They said no sign of particulates in the old fluid. Ideas?
Old Jul 25, 2022 | 06:33 AM
Moparite's Avatar
Moparite
Around 45 it will go into OD, Is it OD or lock up? Lock up will be about 200 rpm difference.
Old Jul 26, 2022 | 07:32 PM
I"m Ike's Avatar
I"m Ike
Default OD
Doesn't do it if locked out of overdrive. RPN fluctuation is about 200-300 rpm.
Old Jul 26, 2022 | 07:33 PM
I"m Ike's Avatar
I"m Ike
DVM=Digital Volt Meter?
Old Jul 27, 2022 | 07:25 AM
dodgetruck2
correct
Old Jul 27, 2022 | 07:49 PM
I"m Ike's Avatar
I"m Ike
Default AC Voltage
On my digital volt meter 200 setting it reads 2.99 to 3.0. Too Much?
