2001 Ram 1500 High beam on one side low beam on ther side
Old Aug 4, 2022 | 11:16 PM
Sugarfoot421's Avatar
Sugarfoot421
Default 2001 Ram 1500 High beam on one side low beam on ther side
I just purchased a 2001 Ram 1500 and noticed that when i turn the headlights on the driverside is high beam and the passenger side is low beam. When i switch the high beams on it all flip flops. What should i do so my low beams come on together?
Old Aug 5, 2022 | 12:32 AM
DerTruck's Avatar
DerTruck
Make sure you have the correct light bulbs. See https://blog.betterautomotivelightin...and-9007-bulbs The non-sport model uses 9004. This is a frequent source of confusion especially with chinese LED lights that pretend there is no difference.
Old Aug 6, 2022 | 11:41 AM
Sugarfoot421
I have a laramie or at least the truck has a laramie badge. Does that make a difference
Old Aug 6, 2022 | 11:46 AM
Does it have the sport package? (4 headlamps, instead of 2)
Old Aug 6, 2022 | 12:00 PM
AtomicDog's Avatar
AtomicDog
When I converted to the sport headlight system and wiring harness, I ran into the same issue. I replaced the headlight bulbs that came with the aftermarket sport headlights with American Sylvania Silverstars which solved the problem for me.
Old Aug 6, 2022 | 12:26 PM
Sugarfoot421
I have the main headlights and the small circular fog lights. I went and took the bulbs out and i have one 9007 and one 9004. Im unsure what is the correct one to keep.
Old Aug 6, 2022 | 12:41 PM
I believe you want the 9004....
Old Aug 6, 2022 | 12:44 PM
Sugarfoot421
Ok thank you all very much.
Old Aug 6, 2022 | 01:56 PM
AtomicDog's Avatar
AtomicDog
If you have a 4 bulb headlight system, the bulbs should be 9004 and 9007. If you have the two bulb headlight system, the bulbs should be 9004.
Old Aug 7, 2022 | 02:58 PM
Moonpie's Avatar
Moonpie
Whichever one came from the side that is working correctly!
