Best procedure for installing gaskets.
Old Aug 21, 2022 | 11:33 PM
  #21
Keith_L's Avatar
Keith_L
The cover is located by numerous bolts but also the oil pan gasket and thus shape of the oil pan. While most bolts run horizontally into the block there are two that run vertical through the oil pan.
Bottom line, the cover is located at far too many points and in two different planes for the seal to have any influence on its positioning.
YMMV but I wouldn't lose any sleep over (see edit) installing the balancer first.
edit: over NOT installing the balancer first and/or not even having a balancer in your possession at the time of timing cover install
Old Aug 22, 2022 | 08:15 AM
  #22
Fel Pro gaskets will be fine.
Old Aug 22, 2022 | 09:17 AM
  #23
Adobedude's Avatar
Adobedude
YMMV but I wouldn't lose any sleep over installing the balancer first.
You mean after the timing cover first, right?
Old Aug 22, 2022 | 09:41 AM
  #24
Keith_L's Avatar
Keith_L
Absolutely. If replacing the balancer don't bother with the "with sleeve" kit as the sleeve would go on the old balancer if needed
Old Aug 22, 2022 | 09:51 AM
  #25
Keith_L's Avatar
Keith_L
If you look carefully at this pic from my thread
https://dodgeforum.com/forum/2nd-gen...er-and-wp.html
and zoom in you can see the 2 vertical bolts at oil pan/timing cover interface (removed in pic) above the trans lines. You can also see you're sucking a radiused timing cover into a radiused oil pan cutout. The balancer itself will be doing NO locating here IMO.
YMMV. Your experience may vary. Not legal in all 50 states. Check local laws before use.
Old Aug 22, 2022 | 12:12 PM
  #26
96albertaram's Avatar
96albertaram
I just bought the balancer and have everything now. So what order should I install then?
Old Aug 22, 2022 | 05:13 PM
  #27
Timing set, timing cover, water pump, balancer.
Old Aug 22, 2022 | 05:25 PM
  #28
96albertaram
I put the cover on with the 4 bolts temporary then the balancer then torqued the bottom timing cover bolts then the water pump. Seem to work out ok. Hope I sealed everything right
look how much my balancer separated
