Need Help - Fuel Pump?
Old 08-22-2022, 05:16 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,219 Likes on 2,970 Posts
Delphi or Denso were OEM. I would stick with one of those two brands, as the others tend to fail rather quick. Sure, they may be cheaper, but, how often do you wanna change the pump?
Old 08-23-2022, 10:42 PM
Daktal's Avatar
Daktal
Daktal is offline
Originally Posted by Keith_L
You can rent a fp gauge at chain auto parts stores for free.
If you're not near an O'Reilly, AutoZone, Advance, etc, you can buy a fp gauge for $30 at HF
https://www.harborfreight.com/fuel-i...ter-58760.html
If you're not near a HF they'll ship it to you for an additional $6.99
You can also get a Bosch on Amazon for $26.50 delivered
https://smile.amazon.com/Bosch-FIX-7...s%2C263&sr=8-5
Here's a different kit with quick connect for various fittings at $25 and there's presently a 10% coupon
https://smile.amazon.com/faersi-Fuel...-1-spons&psc=1
Hey, alright! Thanks!
Old 08-23-2022, 11:00 PM
Daktal's Avatar
Daktal
Daktal is offline
Thats a good point. I was looking at one from A-Premium. It's only $50. But, i don't want to have to do this again.
Old 08-23-2022, 11:30 PM
Keith_L's Avatar
Keith_L
Keith_L is offline
Was that the entire module or just the pump?
I actually don't know if these Dodge modules can be popped open to replace just the actual pump? I've come to believe this is not a terrible option if available.
Just like re-booting CV's most shops won't bother replacing JUST a pump because of labor time, but for a guy on a budget it's worth it. Plus sometimes aftermarket sending units are less reliable or accurate than used OEM
Old 08-23-2022, 11:43 PM
Daktal's Avatar
Daktal
Daktal is offline
Here, check it out:
Fuel pump Fuel pump
Old 08-24-2022, 12:33 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Post
Here, check it out:
Fuel pump
Please use an OEM pump. Delphi or Denso and your truck will thank you. Shop around for one of these at a good price.
Nothing worse than doing that replacement job twice!
The following users liked this post:
Daktal (08-24-2022)
Old 08-24-2022, 10:13 PM
Keith_L's Avatar
Keith_L
Keith_L is offline
Here, check it out:
Fuel pump
I would run far away. Actually if you use that you'll probably get to run FROM far away....
The following 2 users liked this post by Keith_L:
Daktal (08-25-2022), Hero6 (08-26-2022)
Old 08-24-2022, 11:59 PM
Sirriggs's Avatar
Sirriggs
Sirriggs is offline
Keep in mind that the two pumps Hey suggested are good pumps but don't get concern if you go with them and don't hear the pump as you did. delphi pump is what I used and it makes no sound at but working great. good luck.
Daktal (08-25-2022)
Old 08-25-2022, 01:42 AM
Daktal's Avatar
Daktal
Daktal is offline
LMAO alright, alright; point taken. I'll hunt up one of the recommended brands​​​​. Apreciate the help guys.
AtomicDog (08-25-2022)
Old 08-29-2022, 04:31 PM
Daktal's Avatar
Daktal
Daktal is offline
Had a friend work the key while I checked for FP sound and checked the relay. No sound from the pump but the relay clicks nicely. I'm going to go ahead and buy this fuel pressure tester because it seems like it'll have any adapters I might need. And it seems like a handy tool to have. But, it sure looks like I'm going to be replacing the pump. I did manage to find a
Delphi pump Delphi pump
for a reasonable price. That ought to make Keith and Hey You happy.
With the crank/no start, no fuel pump sound, good relay, thumping the tank to get it to start symptoms, how much more testing would you guys do before breaking down and buying that pump? I mean, I can check for air and spark easy enough. But, I don't relish the idea of trying to get a multimeter on the power line for the pump to see if it's getting power.
Quick Reply: Need Help - Fuel Pump?
