Have some new problems after the truck sat
Old Nov 10, 2022 | 07:07 PM
CheeseWheel's Avatar
CheeseWheel
Default Have some new problems after the truck sat
So my 99 ram 1500 4x4 has been sitting for about a year now while I build a flatbed and sort out some transmission issues. I got the bed done and the trans fixed so I went to drive it for the first time outside my backyard. I moved the truck about a month ago and didn’t have these problems. I also started the truck fairly regularly to make sure the battery didn’t go totally dead and the fuel didn’t separate.
first problem, I have no turn signals or hazards, I just replaced the flasher module because the old one was broken. I had both less than two days ago.
Second problem, when I press the brake pedal my speedometer starts dancing around and doesn’t work normally and the abs light is on.
third problem is the trans won’t shift. I assume the tv cable needs to be adjusted but if anyone has other ideas that would be helpful. It shifted just fine before I parked it.
i believe the battery may be going bad. It holds a charge but cranks weak, could this cause any of the issues?
Old Nov 10, 2022 | 07:11 PM
Bad ground somewhere. Likely one of the ones under the dash.
Old Nov 10, 2022 | 07:12 PM
CheeseWheel
I’ll check under the dash tomorrow, the wiring is bizarre under there from the previous owner do I dont doubt that one bit.
Old Nov 11, 2022 | 04:14 PM
CheeseWheel
trans problem was because of the speedo, it’s shifting now. Any tips on how to make it have more grunt at take off? It shoots to 2000rpm until about 25 then starts moving through the range but doesn’t have much power until it gets out of that mode.
Old Nov 11, 2022 | 06:13 PM
AtomicDog's Avatar
AtomicDog
What gear ratios are in the front and rear differentials and what size tires does the truck have?
Old Nov 11, 2022 | 06:20 PM
And: Fixed the plenum yet?
Old Nov 11, 2022 | 07:21 PM
CheeseWheel
3.55 and 32x7 they’re just rollers basically from my old car
CheeseWheel
I have not, I keep forgetting that needs to be done
Old Nov 11, 2022 | 08:44 PM
Do the plenum, water pump, and timing chain/gears at the same time. Can do it in a weekend. You will be AMAZED at how much different the engine runs.
Old Nov 11, 2022 | 08:45 PM
CheeseWheel
wow, ok I’ll get to that next week when I have some time. Thanks for the advice
