Water pump / timing cover torque specs
Old Nov 17, 2022 | 04:33 PM
Keith_L's Avatar
Keith_L
Also my dad once knicked the o-ring on the heater hose tube that enters the wp and that caused a leak.
Old Nov 17, 2022 | 08:25 PM
96albertaram's Avatar
96albertaram
Ah man that sucks. The new water pump came with new tube and o ring I feel like it's solid. Leak is coming from higher and trickling down the sides. Im thinking thermostat housing or the heater core hose is cracked next to it. I mean I hope!! Easiest fix
Old Nov 17, 2022 | 08:28 PM
96albertaram
Originally Posted by AtomicDog
The heater hose clamps are good things to check and possibly tighten as well, however, the bypass hose comes off the front of the intake and goes down into the water pump, just below the thermostat housing.
I just have the spring clamp style on all the hoses . And yes when I got the new water pump it came with a new tube and o ring I feel like it's good. Seems to be the leak is up higher. And the weird thing is it doesn't leak all the time sometimes thee is a pool around the thermostat and sensor areas sometimes not. Also a tricky coming down the sides of timing cover. I'm hoping it's from the leak above !
Old Nov 18, 2022 | 12:04 AM
AtomicDog's Avatar
AtomicDog
I use the worm style clamps when I replace hoses and/or the water pump, so that I can easily tighten them with a screwdriver/nut driver in the event of a leak.
Old Nov 18, 2022 | 12:50 PM
Adobedude's Avatar
Adobedude
Spring clamps are the way to go.
Old Nov 18, 2022 | 12:53 PM
Those guys tend to bite me.
Old Nov 18, 2022 | 02:31 PM
AtomicDog's Avatar
AtomicDog
I really would like to use Wurth zebra clamps, however, they are just a bit overpriced - I like the gear being on the outside of the clamp to keep the clamp band from digging into the hose over time - https://www.wurthusa.com/Service-and...SAAEgIZkvD_BwE
For most hose repair jobs, I just use the old-fashioned, tried and true Ideal worm clamps - https://shop.advanceautoparts.com/p/...061/11863868-p
I typically replace the factory style spring clamps with worm clamps as repairs/replacements come up.
Old Nov 18, 2022 | 05:37 PM
96albertaram
Ya hey? I feel like the gear clamps wear out hoses faster because they can always be over tightened overtime or from the next guy. Where as the spring clamp is always the same tension. Either way they both hold good and will cause stress in that area first
