Rebuilt ABS Controller
Old Nov 17, 2022 | 06:11 PM
Sirriggs's Avatar
Sirriggs
Need to bleed the rears then. But, start by bleeding the FRONT. Pump 'em up, hold heavy pressure on the pedal, crack open a bleeder valve in FRONT. That will shock the proportion valve to allow flow to the rear. (might have to do it a couple times.)
I plan on doing a full bleed on all four. Hopefully I get the new module by Saturday but if not, It will be here by Tuesday. Either way, Should be back up and going soon. My biggest concern is the module is shutting off or constricting fluid to the rear. The right rear emergency brake cable also was frozen so it has been disconnected so I also either need to get it freed up or replaced. I can't remember the last time it was used but we did find out it was stuck in the on position so I don't know how long it was like this. To be hinest, with the time it sat. I'm surprised there isn't more things that will show up to be fixed. Sitting like that is hard on any truck or car. Thanks for the advice. Well taken.
Old Nov 17, 2022 | 06:21 PM
If you only have RWAL, changing that feller probably isn't going to fix anything. The proportioning valve has a safety valve in it, so, if one brake circuit or the other fails, a piston moves to seal it off. Bleeding your brakes can trip the valve, and then you have to do hoop jumping to get it to reset.
I *think* the dump valve is separate? Isn't it??
Old Nov 17, 2022 | 06:49 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Have a link to the ebay guy?
Old Nov 17, 2022 | 07:13 PM
Sirriggs's Avatar
Sirriggs
What I will do since it's dark by the time I get home. I will get some pictures of my system. I'm not sure what RWAL is? My module has a three plugs. On going to the valve where the fluids come in then out to the rear. Looks like two cylinders when connection in between. This is my first time dealing with ABS issue so not sure everything name. lol
Old Nov 17, 2022 | 07:29 PM
AtomicDog's Avatar
AtomicDog
I believe RWAL (Rear Wheel Anti-Lock) is rear wheel ABS only and not 4 wheel ABS. Sounds like you have only rear wheel ABS if the line coming off the ABS module is only in-line with the rear brakes.
Old Nov 17, 2022 | 10:02 PM
Sirriggs's Avatar
Sirriggs
That makes sense. Just never heard the term lol. Yes it's a rear brake issue. Thinking about pulling some line loose and blowing them out to make sure they are clear. I just have to find someone to help. Daughter on a cruise with bf and his family. Doing a full system clean and bleed would ensure everything is working as intended.
Old Nov 18, 2022 | 08:36 PM
Sirriggs's Avatar
Sirriggs
I have a question. Is there a possibility that since my rear rear cylinder was leaking and brakes were completely gone down to the the point that it killed my drums that the proportional valve may have thought a line went and cut off the fluid to the rear? If so, how could you reset that valve? I know it's a safety deal so you don't loose brakes but cutting off fluid. I am staring to wonder if that is why I am not getting any fluid back to either side. I'm just curious.
Old Nov 18, 2022 | 10:46 PM
AtomicDog's Avatar
AtomicDog
That's quite possible. See if you can find a spot on the brake valve where there may be a rubber cap. If so, firmly press in that area to free/reset the valve. The service manual may have more information regarding the reset process. You can download the service manual for your year truck from here - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Nov 19, 2022 | 08:35 AM
Sirriggs's Avatar
Sirriggs
I will look for that. rubber cap. There really isn't a lot of information or trouble shooting for this. I can understand what it does and what for but how to reset is the question.
Old Nov 19, 2022 | 09:46 AM
Just bleed the brakes again. If you aren't getting fluid to the rear, crack open one of the FRONT bleeders. The valve is sensitive to pressure differences, opening the front will prompt it to want to send fluid to the rear.
