Rebuilt ABS Controller
Old Dec 2, 2022 | 09:23 PM
  #71
Sirriggs's Avatar
Sirriggs
Some codes do seem stubborn, but, disconnecting the battery for a while *should* get rid of 'em. I suppose the trick would be to reset the computer, turn the ignition off, then on, (not start) and check for codes again....
When you say reset the computer. This would mean maybe a overnight battery disconnect? I have heard if you disconnect the battery and take both the positive and negative then touch them together clears computer. The put them back on. Have you heard of this?
It doesn't matter how I search these codes. Nothing seems to help to find a way to solve or clear them.
Old Dec 3, 2022 | 07:46 AM
  #72
I don't like putting the battery terminals together... potentially too much of a shock load on the electronics.... I usually just disconnect the battery, and turn on the headlights. That will drain any residual power, and reset the computer, safely. Will clear most codes as well. (ABS seems to be stubborn on some of them.....)
Old Dec 3, 2022 | 11:10 AM
  #73
Sirriggs's Avatar
Sirriggs
I will try that. They are being stubborn. You would think these codes would be to find information on but they aren't. I know they drive me crazy. lol
I have been working my butt off bringing it back to it's former glory. Minor defects but over all it's a looks good,. Interior wear is normal but slowly getting that fixed as well. Once headliner replaced. My plans are to replace the floor carper( Which is pretty cheap). Figure when seats are out, going to sand and repaint the frame since they have surface rust. 23 years of wear and tear takes it's toll. lol.
Old Dec 3, 2022 | 01:28 PM
  #74
AtomicDog's Avatar
AtomicDog
Might want to try using another scanner to try to pull those ABS codes, if they persist after clearing them. On my '96 truck, the ABS codes can only be pulled via the OBD1 access port, since it's kinda a hybrid OBD1/OBD2 truck. I'm wondering if your scanner is accessing those codes correctly?
Old Dec 3, 2022 | 01:47 PM
  #75
Sirriggs's Avatar
Sirriggs
Here is a link to the one I have. Yeah it's Harbor freight. https://www.harborfreight.com/zr11s-...abs-57665.html
This is suppose to be a decent scanner.
