Power to Ignition Coil but no spark.
Old Dec 14, 2022 | 04:01 PM
Pull a couple plugs, are they wet?
Old Dec 14, 2022 | 04:51 PM
Nate5's Avatar
Nate5
they are not, replaced the camshaft pod sensor and distributor cap rotor, still no spark at coil when I test it.
Old Dec 14, 2022 | 05:04 PM
Nate5's Avatar
Nate5
Originally Posted by Moparite
Power is coming from the asd relay, Coil will not fire unless the pcm sees inputs from both crank and cam sensors. A test light is not the best method to test it.
You tested this while cranking the motor correct? Should not be constant.
I am getting a constant dim light, test light to negative wire that plugs into ignition coil, alligator clip connected to pos battery terminal.
Old Dec 14, 2022 | 06:19 PM
Unplug it from both ends, test continuity of the wire itself, and also continuity to ground.
Old Dec 15, 2022 | 03:53 PM
Nate5's Avatar
Nate5
do you know what plug in is the wire for the coil
Old Dec 15, 2022 | 04:16 PM
C1 pin 7, Black with grey trace.
Old Dec 15, 2022 | 10:33 PM
Ugly1's Avatar
Ugly1
also if you haven't done it already, checking the resistance of the primary and secondary winding on the coil can be done to verify the coil itself is still good. There are resistance specs for the coil windings in the manual somewhere, presumably.
Old Dec 16, 2022 | 07:55 AM
Cmcs24fan's Avatar
Cmcs24fan
Have checked spark coming out of the coil? Maybe the problem lies in the wire going to the distributor? Had a similar problem that ended up being the pick up coil under the distributor cap and rotor.
Old Dec 16, 2022 | 12:51 PM
Nate5's Avatar
Nate5
This is how I have my meter set up, I am getting 00.3 on reading testing pin 7 and negative wire to coil
Old Dec 16, 2022 | 01:02 PM
That should mean the wire is good...... Though the infinite resistance in your pic of the meter might be a problem? Or is that just to show the settings on the meter, and not the actual reading?
Test from the wire (either end) to ground as well. (unhooked on both ends) See what ya get.
