Multiple cylinder misfire cylinder 1 misfire cylinder 2 misfire
Old Jan 15, 2023 | 08:32 PM
Snicholl93's Avatar
Snicholl93
No I haven’t checked yet but it smells like gas when it starts to do that.
Old Mar 28, 2023 | 06:04 PM
Snicholl93's Avatar
Snicholl93
Default Update
So I changed out the plenum play gasket and all that came with the kit and it seems to be running much better. I also changed out the alternator battery steering box and alternator fuse (it blew when I was booking everything up). Next step is the transmission bands I’m thinking I might just try to change them out unless it would be better to just try to tighten them first. It shifts hard sometimes and takes a while for it to really get going from stopping.
Old Mar 28, 2023 | 07:01 PM
Are you getting all your gears?
Old Mar 28, 2023 | 08:10 PM
Snicholl93's Avatar
Snicholl93
Default Ummm
It seems like it’s hitting all the gears.
Old Mar 29, 2023 | 07:04 PM
Fix the misfires, and it should have better power out of the hole again. If that's a gas V-8, have you fixed the plenum? That will also destroy power below about 3K RPM. If it's high mileage, changing the timing chain/gears wouldn't hurt either. (double roller set please.)
Try and adjust the bands first, and also make sure the TV cable operates properly, and is adjusted right.
Old Apr 4, 2023 | 08:20 AM
Snicholl93's Avatar
Snicholl93
Default New codes
Misfires in cylinder 1/2 random misfire Governor pressures solenoid conditions and torque converter solenoid. When I start it in the morning I have to give it gas to keep it running but after a little while of driving it stabilizes. Not sure what’s going on there.
Start with cleaning the throttle body.
Old Apr 4, 2023 | 08:22 AM
Snicholl93's Avatar
Snicholl93
I cleaned it when I changed the plenum plate and all.
What spark plugs ya have in there? How old? Cap? Rotor? Wires??
Old Apr 5, 2023 | 02:27 PM
Snicholl93's Avatar
Snicholl93
Default Hmmm
I’m not sure of the brand but maybe I should do a tune up on it after the other issues.
