Multiple cylinder misfire cylinder 1 misfire cylinder 2 misfire
Old Apr 6, 2023 | 09:35 AM
  #21
Sure wouldn't hurt. Standard copper plugs though please.
Old Apr 23, 2023 | 12:22 PM
  #22
Snicholl93's Avatar
Snicholl93
Default Sensor
Does anyone know what sensor is supposed to be here?
Old Apr 23, 2023 | 12:42 PM
  #23
Inlet for the egr tube from the passenger side exhaust manifold. If your truck is 96 or newer, it won't have EGR, and there will be a block-off plate where the valve is supposed to be. Nothin' goes there in that case.
Old Apr 23, 2023 | 02:13 PM
  #24
Snicholl93's Avatar
Snicholl93
Default Different truck.
This is for a 96 5.9. My buddy is wondering what exactly it is.
Old Apr 23, 2023 | 07:46 PM
  #25
My 96 was the same way. It seems that Dodge had some leftover EGR manifolds they wanted to use up, as opposed to just scrapping them.
Old Jul 5, 2023 | 04:22 PM
  #26
Snicholl93's Avatar
Snicholl93
Default Still
So I changed the plenum plate and gasket however it sent like it’s burning more oil now then before. I torqued everything in accordance with the specs and all but it’s going through about a quart a month. Any advice?
Old Jul 5, 2023 | 07:03 PM
  #27
Valve cover gaskets? Leaking out the rear of the intake? (china wall seal.) Compression test?
Old Jul 5, 2023 | 08:34 PM
  #28
Snicholl93's Avatar
Snicholl93
Default Hmm
I’ll have to check it when I get a chance.
Old Oct 31, 2023 | 09:29 PM
  #29
limpdaddy215's Avatar
limpdaddy215
Did you ever do a compression test?
Old Sep 1, 2024 | 02:09 PM
  #30
muchgorilla's Avatar
muchgorilla
Default Did you fix the mis fires I have no transmission problem the oil problem due to plenu
Misfires in cylinder 1/2 random misfire Governor pressures solenoid conditions and torque converter solenoid. When I start it in the morning I have to give it gas to keep it running but after a little while of driving it stabilizes. Not sure what’s going on there.
I need help did the plenum fix the mis fire I have oil leak to
