No overheat, no overdrive, light is always on
Old Jan 15, 2023 | 09:50 PM
Then you have a short to voltage somewhere on that circuit. Unplug the switch, it might just be that easy.
Old Jan 15, 2023 | 10:26 PM
new2forum's Avatar
new2forum
will try that in the morning. I have a parts truck that has a matching OD switch. I have that one off now, I see it has four wires to it. Will install it, and get back. Thanks
Old Jan 16, 2023 | 07:00 PM
new2forum's Avatar
new2forum
So, it comes to pass. I installed the replacement switch, and then the computer, and then even tried no switch at all. I did get overdrive for about two miles then it shut back off. This happen when I took the battery cable off. Waited for a bit Changing the PC.
I might be tempted to cut the signal return wire from the O/D switch, just to see if the behavior changed.
Old Jan 16, 2023 | 08:17 PM
Need a scanner that can read (logging would be nice too) live data. See what the PCM thinks is going on. Should give a clue as to why it won't shift.
