The NeverEnding Story II: 2001 1500 4x4 9.25 Rear Axle: Pinion Nut
When I took this thing apart, there was no washer under the pinion nut. (I verified because I had videoed me removing the nut, and I went back and watched in slo-mo.)
The nut style/shape was this:
When I bought a new nut from the dealer I received the same style.
From what I remember from all the videos I've watched of disassembly and assembly the nuts were of this type/shape:
And they had a washer.
I've tightened the new nut down to the specified 210 ft-lbs, but haven't yet moved on to the next step of checking the rotating torque using the in-lbs wrench and tightening more if need be.
I haven't moved on because there is still a little bit of front-to-back play when I pull and push on the flange, and I wasn't sure if I needed a washer....???
Well, after checking the rotating torque and seeing that it was very loose and not even close, I went ahead with tightening up without a washer. It took forever trying to go a little at a time, but it turns out at the end that I went too far the last time and overtightened.
So it seems that maybe I don't need a washer - but I do now need to go get another crush sleeve (or two) and try again....
But when you say, "Both will work the same," do you mean that a flange nut needs a washer just like the other nut type does? Or that the flange nut by itself works the same as the other nut + washer? (Or something else that I'm just not understanding?)
I'm kinda thinking the flange nut was OEM and what you got was aftermarket so just needs a washer. If your original flange nut didn't have a washer I'd say that's your answer there.
I work with vehicles for living that have tons of flange nuts, and they don't have additional washers under them. Washer is kind of built into the flange nut.
To clarify, I purchased an OEM replacement from my local dealer, and it is a flange nut.
The one I removed was a flange nut and had no washer.
I know the "rear-end" was replaced shortly after I got the truck many moons ago; but I didn't know enough then and don't remember the details to recall exactly what that entailed.
This whole extended project is my first time ever doing anything with a differential other than replacing gear oil, so I do not have experience to lean on.
