Torque converter problems (maybe)
#22
Definitely the wrong color. What's up with the valve body screws? With the magnet full of fine particles the transmission looks tired and used. I suggest a full rebuild with a new/rebuilt low stall torque converter. JY transmissions are a crapshoot. You can't go by mileage as I only had 86K on mine with 2 clutch packs burnt when I rebuilt mine.
#23
Man, yours look horrible compared to mine when I dropped it. My magnet was clean. I just did my first rebuild and these guys have helped a lot. The rebuild wasn't really bad but I had to get a press to do my overdrive due to spring under dangerous load. That I will admit was little scary but I did it. I'm just working some bugs out on mine. If you look at my ongoing post. I have link there that walks through a 46re to 48 rebuild from tear down to reassembling. Good luck Sir. I wished I could help.
#24
#25
#26
#27
#28
#29
#30
