Mystery leak inspection plate+ oil pressure abnormality
Old Sep 15, 2023 | 02:44 PM
  #21
magnummaniac's Avatar
magnummaniac
Originally Posted by AtomicDog
Home Depot, Lowes (in this area) or a local well-stocked hardware store should carry brass fitting that will take care of this issue. The fittings are likely 1/8" NPT threads.
thank you so much!
Old Sep 15, 2023 | 03:15 PM
  #22
Darren Davis's Avatar
Darren Davis
So, a failing cluster causes oil leaks?
or was there something else going on also?
Old Sep 15, 2023 | 03:19 PM
  #23
magnummaniac
I apologize for the confusion! My “leak” was residual oil from the previous rear main seal leak and it was coming out of the bell housing through the gap located bottom center on the inspection plate.
My frequent and alarming oil pressure fluctuations are attributed to the failing cluster
Old Sep 15, 2023 | 04:08 PM
  #24
AtomicDog's Avatar
AtomicDog
Lightbulb
Just an FYI, if desired, you should be able to find a good used cluster via car-part.com or eBay... They are pretty easy to swap out. Just make sure that you get one for the correct year truck.
Old Sep 15, 2023 | 04:12 PM
  #25
magnummaniac
I was checking some out on eBay. I’ll definitely explore car-part.com. I’m going to go the mechanical route first to make ensure accurate readings and space out the spending. May replace the cluster if I get tired of hearing the pressure alarm go off
Old Sep 15, 2023 | 06:05 PM
  #26
I have rarely seen a cluster fail.... I HAVE seen pressure sensors fail.... even new ones.
Old Sep 15, 2023 | 06:17 PM
  #27
magnummaniac
That makes a ton of sense- especially since a duralast sensor was all I could get my hands on when I needed it quick. I’ll dig around and see if I can find an OEM one
Old Sep 15, 2023 | 06:22 PM
  #28
magnummaniac
Any suggestions on brand if I can’t find mopar spec? I’ll call a dealership tomorrow
quick glance shows rock auto has rostra, standard motor, and wve
Old Sep 15, 2023 | 09:49 PM
  #29
Keith_L's Avatar
Keith_L
Yep the beauty of most of this stuff is that it's NPT....so Home Depot, Ace, True Value, Lowe's etc!!
Old Sep 16, 2023 | 07:08 AM
  #30
Moparite's Avatar
Moparite
Consensus was the gauge cluster is on its way out.
Did they tell you how they came to that conclusion? Did you possibly do the dash test?
