Mystery leak inspection plate+ oil pressure abnormality
Old Sep 11, 2023 | 12:11 PM
magnummaniac's Avatar
magnummaniac
Originally Posted by Moparite
Did you loosen the caps(to lower the crank) or do it in place? You may want to remove the plate and get a better look at where it may be coming from.
I took the rear cap off but didn’t have to loosen any of the others. Upper half of the seal came right out
Old Sep 12, 2023 | 12:10 PM
Darren Davis's Avatar
Darren Davis
Have you solved the issue you're having? Reason I'm asking is because I'm having the same issue. I've replaced the plenum and intake manifold gaskets, oil pressure sensor, oil pump, rear main seal, oil pan gasket, and change the oil. Yet, still leaking oil in the same area as you and don't know where it's coming from or what is making it leak like it is.
Old Sep 12, 2023 | 12:16 PM
magnummaniac
Sounds like we’re identical. I did the Hughes plenum fix a month ago. As for the oil leak, since I replaced the rear main seal and oil pan gasket (transmission remained on and wasn’t cleaned), I suspect that it’s residual oil from the previous leak getting pushed out through the bell housing. Nothing on the inspection plate or pan. It’s definitely used oil that’s leaking. I haven’t lost new oil. As for the fluctuating oil pressure, I’m starting to suspect a worn crankshaft and bearings. Which I’m not stoked about. Keep me posted! Curious what your issue ends up being.
Old Sep 12, 2023 | 02:21 PM
magnummaniac
Are you getting weird oil pressure readings? Does your leaking oil look used or is it fresh? If no weird pressure readings and it looks like used oil, I’d clean the oil off the bell housing and just drive it- be sure to check for leaks and monitor the oil levels religiously. As mentioned previously in this thread, I’ll be installing a mechanical oil pressure gauge as well.
Old Sep 13, 2023 | 09:32 AM
Darren Davis
No, not having any oil pressure drops after replacing the oil pressure sensor but still slowly leaking oil. I've wiped out the inside and bottom of the bellhousing quite a fews times and I'm sure it's fresh oil slowly leaking since I've been having to put a couple quarts back in every week or so. It's kinda starting to really pissing me off that I can't find where it's coming from
Old Sep 13, 2023 | 06:13 PM
Put some dye in your oil. Drive it for a couple days, then break out the yellow glasses, and UV flashlight.
Old Sep 13, 2023 | 07:54 PM
magnummaniac
I did the unspeakable and dropped it off at a shop. I hate it. Thank you to everyone that’s chimed in and I’ll update this post when I learn more
Old Sep 15, 2023 | 02:13 PM
magnummaniac
Originally Posted by Keith_L
Even the cheap Sunpros or Autogage (or whatever they're called now) should be fine. No need to shell out for Autometer, although it may come with nicer nylon tubing -- not sure.
You can also try to just temporarily plumb it onto your cowl or thru the driver window-- anyplace you can see it while driving, and see if the symptoms truly exist while driving. If you can tee it at the block then it's REALLY fun to compare mechanical (almost surely accurate) to the dash gauge (who knows, maybe kinda-sorta).
any direction on where to find the appropriate tee fitting for this? Just ordered an autometer + pod
Old Sep 15, 2023 | 02:14 PM
magnummaniac
Consensus was the gauge cluster is on its way out. I rolled the dice and drove it 500 miles the same day I got it back from the shop. No issues whatsoever. I’ll be plumbing in a mechanical gauge when parts arrive next week
Old Sep 15, 2023 | 02:43 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Home Depot, Lowes (in this area) or a local well-stocked hardware store should carry brass fitting that will take care of this issue. The fittings are likely 1/8" NPT threads.
