No air through any vents
Old 09-15-2023, 08:20 AM
Trucker186's Avatar
Trucker186
Trucker186 is offline
Originally Posted by Moparite
You won't be able to see the inlet from inside but put it on 'max ac recalculate" and the door will move and then you will be able to see it. I think if you remove the fan and stick your hand in there you can feel the evaporator. Did you verify you are not getting air out the defrost vents?
All of my vents get the same weak amount it seems. I'll try that and see what I can do.
Old 09-15-2023, 10:59 AM
Trucker186's Avatar
Trucker186
Old 09-15-2023, 11:00 AM
Trucker186's Avatar
Trucker186
it seems to have some pine needles etc in there but doesn't look too clogged. I've noticed I think I hear/feel some air behind the dash.
Old 09-15-2023, 11:09 AM
Trucker186's Avatar
Trucker186
So I ran a camera I have into there and found this. I guess that's probably clogged up and is my issue ?
Old 09-16-2023, 07:46 AM
Moparite's Avatar
Moparite
Moparite is offline
The other pic shows open area so it may be restricted partially you still should feel air out the vents. See if you can vacuum out all the garbage in there. Test it in defrost mode, That's the default position if you have no vac or weak vac to power the actuators you will get air out of them.
Old 09-16-2023, 10:29 AM
Trucker186's Avatar
Trucker186
I tried cleaning it some with my hand and I have a slight amount of air coming through now. I get the same air flow on all settings including defrost. I ordered a kit to blow the evaporator out.
Old 09-17-2023, 10:50 AM
Moparite's Avatar
Moparite
Moparite is offline
Got a link to this "kit"?
Quick Reply: No air through any vents
