No air through any vents
Old 09-13-2023, 11:08 AM
Trucker186's Avatar
Trucker186
Trucker186 is offline
Default No air through any vents
Hi,I'm new to the forum. I'm having some issues with my 1995 Dodge 2500. Recently I had noticed my vents weren't blowing very strong and that the blower motor seemed to be getting tired. I ordered a new one,installed it and the blower motor itself sounds very healthy,except now I have a new issue. I have no air or a very very weak amount of air coming out of any of the vents. It is selecting the vents correctly,the door nearest the blower motor is operating correctly,I cannot figure out what's gone wrong. I don't think it's a vacuum issue as I can hear it switching vents,and I feel a light amount of air coming out of each (so light it won't even blow a piece of paper,it lays flat). Any ideas ?
Old 09-13-2023, 06:11 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,395 Likes on 3,135 Posts
Do you have A/C? Did you check for junk in there while you had the fan out?
Old 09-13-2023, 06:41 PM
Trucker186's Avatar
Trucker186
I do when I charge it. It leaks but I had a/c up until I changed the fan. I had mediocre at best air flow till the day I changed the fan,now its none.
Old 09-14-2023, 06:51 AM
Moparite's Avatar
Moparite
Moparite is offline
Does the fan run on high? You should hear it regardless of where the air comes out at.
Old 09-14-2023, 08:02 AM
Trucker186's Avatar
Trucker186
Yes it does. I can hear the fan and it sounds strong.
Old 09-14-2023, 08:04 AM
HeyYou is offline
Pull the fan, look at the evaporator core. (assuming you also have a/c) Is it packed full o' stuff? Also check the inlet for the fan.....Make sure that isn't all packed up as well.
Old 09-14-2023, 08:30 AM
Trucker186's Avatar
Trucker186
where is the evaporator at when I pull the fan ? Where's the inlet for the fan ? Sorry for the basic questions I've just never worked on HVAC.
Old 09-14-2023, 12:21 PM
HeyYou is offline
Should be able to see it... maybe a flashlight and mirror would help?
Old 09-14-2023, 12:41 PM
Trucker186's Avatar
Trucker186
It should be towards the driver's side of the truck correct ?
Old 09-15-2023, 06:42 AM
Moparite's Avatar
Moparite
Moparite is offline
You won't be able to see the inlet from inside but put it on 'max ac recalculate" and the door will move and then you will be able to see it. I think if you remove the fan and stick your hand in there you can feel the evaporator. Did you verify you are not getting air out the defrost vents?
Quick Reply: No air through any vents
